The "Quantity field" option in "Product features display" does not work.
6 years 4 months ago #282921
-- Joomla version -- : 3.8.2
-- PHP version -- : 5.6.3
-- Browser(s) name and version -- : Chorme V62.0.3202.94
I created a new module called HikaShop Content Module and named it Best sellers. Pls check image: prntscr.com/hdok0h
Then I configure the module at the tab Hikashop Options -> check image:
prnt.sc/hdolmk
Here in the "Product features display" tab I uncheck Quantity field -> check image: prnt.sc/hdom8m
When I go outside the frontend and check the Quantity is not hidden. -> check image: prnt.sc/hdon6d
But when I choose to hide "Add to cart", it hides the add to cart and quantity field -> check image: prntscr.com/hdoo3y
prnt.sc/hdood3
Please respond to me soon, because I need to finish it in a day. Thank You.
  • Thank you received: 13037
6 years 4 months ago #282928
I'm not able to reproduce the problem.
It works fine on my end.
First, please switch to the default template of Joomla and check that you have the same problem. Because it could actually come from an old view override.
If that doesn't help, please provide a screenshot of the settings of the product and of the settings under the Display and Advanced tabs of the HikaShop configuration as they too can have an influence on the display of the quantity field.
6 years 4 months ago #282929
6 years 4 months ago #282932
I looked at the video, but unfortunately, it doesn't answer any of the questions of my message.
So again:
6 years 4 months ago #282941
Hi!
In a nutshell. My problem is that outside the product listing page I do not want to display Quantity Field. On the product details page, the Quantity Field still shows normal. So how do I do? You can specifically instruct how config helps me. Thank You.
6 years 4 months ago #282948
On the product page, it's the setting from the HikaShop configuration which is takend into account: "Quantity input method"
Set it to "none" and it won't display the quantity input field.
6 years 4 months ago #282979
I would like the quantity field list page not to display this page:
demo.hikashop.com/index.php/en/hikashop/...sting/display-in-div
And on the product details page, the quantity field appears as this page:
date.hikashop.com/index.php/en/hikashop/...oduct/1-pink-sandals
How can I do that?
6 years 4 months ago #282984
The settings you've shown previously looks ok to do what you want, which is why I've been requesting additional information in order to try and understand why you have that behavior.
Now, if you could test and provide the things I talked about before that would help us move forward on that topic...
6 years 3 months ago #283914
Hi.
I did what I wanted to do. Now I have a problem wanting you to help.
1. I created a cart module and wanted it to look like this: prntscr.com/hjsvwj
how to config?
Here is the image on my site:
prnt.sc/hjsws4
2. In the product vote. hikashop is using a star image named star.gif. How can I override it and replace it with my image?
Pls help me. Thank You.
6 years 3 months ago #283916
1. You want to turn off the "mini cart" setting of your cart module.
And only activate the show proceed to checkout button, show product name and show prices settings and it will display like that.
2. The stars as defined in the CSS of the main file of HikaShop in media/com_hikashop/css/hikashop.css:
 * Rating
.hk-rating {
	margin:auto;
	display:inline;
.hk-rating a { cursor: pointer; background-color: transparent !important; }
.hk-rate-star {
	width:16px;
	height:16px;
	font-size:2px;
	display:inline-block;
	text-decoration:none;
	vertical-align:bottom;
	background-image:url('../images/star.gif') !important;
	background-repeat:no-repeat;
.hk-rate-star.state-full { background-position:left top; }
.hk-rate-star.state-mid { background-position:left -16px; }
.hk-rate-star.state-empty { background-position:left -32px; }
.hk-rate-star.state-hover { background-position:left -48px !important; }
So you can change it by adding your own CSS to override it.
6 years 3 months ago #284288
Hi!
Thanks for your help. I have a problem you need support. I want the config checkout workflow like demo.hikashop.com. Can you send me snapshot of config in admin? Thank You.
6 years 3 months ago #284291
6 years 3 months ago #284365
Hi. Thank You for Help.
When I configure the same as you instruct the mini module module in the image paypal payment under the checkout button. How to hide it?
prnt.sc/hmupnq
6 years 3 months ago #284373
The solution will probably to directly un-publish the "HikaShop Paypal Express Checkout payment plugin" via "Hikashop->System->Configuration->Payment method".
6 years 3 months ago #284913
Thank You So Much
I want to make this page: demo.hikashop.com/index.php/en/hikashop/.../personalized-layout
On the page layout in the product I do not see the "show_custom" layout like the "Graphic Tablet" product on demo.hikashop.com. Thank You.!
6 years 3 months ago #284921
That's because it's a custom layout that we've written for the demo website, so it's not in HikaShop. The goal was to show that you can easily add new layouts.
You can actually access the layout code via the menu Display>Views in the backend of the demo website:
monosnap.com/file/q2HtkHZUPcjDAvoNqtDa86ICQ7sNFc
So just copy / paste the code in your show_default view file and save and your products will use that layout.
