You've configured a HikaShop content module to display the listing of products and you've configured it to be displayed on the candies menu item.
But you didn't select a products listing menu item in the "menu" setting of your module. Thus, the Itemid in the URLs of the products is 0, meaning that the product page display without a menu item attached to it.
I would recommend to remove / disable that HikaShop content module and instead, change the type of your candies menu item to be a HikaShop products listing. That way, the products will be directly displayed by the menu item and when you click on a product, the product page will also be directly displayed by that menu item. Incidentaly, your logo module, which is also configured to be displayed for that menu item, will display on the product pages too.
