Prod Category text desc not using Read More funct
13 years 6 months ago #93183 by teleactive
In the Product Category when I edit the description text it does not recognize the Read More function to shorten the general description to allow the products to appear toward the top of the page just under the Read More instead at the end of the description.
Please advise of work around or solution.
13 years 6 months ago #93218 by Mohamed Thelji
I think that you'll probably find your answer through this thread :).
13 years 6 months ago #93330 by teleactive
I reviewed the thread and find no code with echo in the Category description text that appear before the products are shown.
You can see the page here.
198.57.141.10/~cllgshp/index.php/product...go-value/colligo-dux
All the Read More code is doing is putting in a horizontal rule seen just before the Warning:Colligo....
Looking for a solution to bring the products closer to top of page but still keep this general product information available.
13 years 6 months ago #93386 by Xavier
Can you edit the view used for the listing, and see if the code:
echo preg_replace('#<hr *id="system-readmore" */>.*#is','',$this->row->product_description);
is present.
And in the product view if the code:
echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description));
is present.
13 years 6 months ago #93674 by teleactive
We are looking at a category listing not a product listing. We can not find either of these lines of code in any of the views files.
Which files with path would should we be looking in.
13 years 6 months ago #93863 by Xavier
To have the readmore in the category description you can edit the view "product / listing" and use "echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->category_description));" in the "hikashop_category_description" div.
Time to create page: 0.210 seconds
