- Thank you received: 2
Product limit not working for Quarterly period
13 years 6 months ago #94655
by rje2001
Product limit not working for Quarterly period was created by rje2001
When I try to use a product quantity limits, the feature works properly for all period choices (cart, daily, weekly, monthly, and yearly) except Quarterly. Also, the 'Limit Reached' method doesn't seem to always display for any of the order types - just 'The cart is empty' if you have reached the quantity limit.
thanks,
Jeff
thanks,
Jeff
13 years 6 months ago #94919
Replied by nicolas on topic Product limit not working for Quarterly period
Regarding the quarterly period, there is indeed a bug (it was a typo).
We've fixed it on our end.
You can fix it by changing the code:
'quaterly' => 2,
'quarterly' => 2,
in the file administrator/components/com_hikashop/classes/cart.php
Regarding the error message, it depends how the add to cart is handled. When you are in AJAX mode, only the cart content is updated on the page so the system messages cannot be displayed by the template on the page since the page doesn't change. You should check that the option "Use AJAX when possible for add to cart buttons" of the configuration is off, like it is by default.
'quaterly' => 2,
'quarterly' => 2,
13 years 6 months ago #94936
by rje2001
Replied by rje2001 on topic Product limit not working for Quarterly period
Thanks Nicolas - that resolved the problem with the Quarterly limits. I also had the 'Use AJAX" option set to on, and turning this off results in the expected error messages - thanks for the excellent help!
Jeff
Jeff
