Problem with view editing
13 years 6 months ago #96518
by Tangram
Problem with view editing was created by Tangram
Hello, i'm having this problem:
When i make a change in any view in the backend and i save it, automatically the code makes a strange thing, it puts this \ everywhere.
Here's an example: defined(\'_JEXEC\') or die(\'Restricted access\');
What happens then in the frontend is that it gives me this error:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING in /home/tangram0/public_html/Extensiones_Demo/Joomla3/templates/protostar/html/com_hikashop/product/show_default.php on line 9
I'll appreciate any help.
13 years 6 months ago #96594
Replied by nicolas on topic Problem with view editing
That's because the magic_quote_gpc option of your PHP is turned on and that you're using Joomla 3.0
It is a requirement that this option is turned off for Joomla 3.0 installation. Please ask your hosting company to turn that off and it will work properly.
Time to create page: 0.142 seconds
