cart module math errors when updating quanities
13 years 5 months ago #99414 by bruntt
When I add a product to the cart, it shows up in the cart module properly in the left column.
If I change the quantity from 1 to 2 in the module, the system updates but multiplies the total times 4 instead of 2. Similar math errors show when inputting different quantity numbers.
You can see what I mean here.
www.bennettsclothing.com/index.php/shop
The total is correct on the checkout page. I can change the quantity on the checkout page, and the math is correct there.
The error only happens in the cart module on the left column.
t
13 years 5 months ago #99432 by nicolas
Please download again the HikaShop package on our website and install it again and that should fix the problem.
The following user(s) said Thank You: bruntt
13 years 5 months ago #99436 by bruntt
That worked. Thanks!
Time to create page: 0.148 seconds
