- Thank you received: 1
Finding and sorting products
13 years 5 months ago - 13 years 5 months ago #99843
by Ronon
Finding and sorting products was created by Ronon
Hello, I would like to know how I can configure the Joomla search to search between products and categories of HikaShop.
I also want to know if is possible to add a module to select various product management criteria. For example to see them sorted by price, by name, availabilities, etc..
Finally wanted to know if there is way to see the list of all products from the backend of HikaShop, choosing instead to go category by category to view.
Thank you very much.
Last edit: 13 years 5 months ago by Ronon.
13 years 5 months ago #99924
by Xavier
Replied by Xavier on topic Finding and sorting products
1. You just have to use a joomla search module, then enable the search products & search categories hikashop plugins.
2. For that, you have to use the filters. www.hikashop.com/fr/support/documentatio...-filter-listing.html
3. In the backend listing, there is filters, just select "all sub elements" for the latest filter and it will display all the products.
Time to create page: 0.157 seconds
