Stay and display a popup notice 404 error
13 years 5 months ago #100291 by briand
I tried a couple of options with regards to the "After a product is added to the cart" and finaly decided to use the "Stay and display a popup notice". But when I tried it recently there is a 404 error showing and it does not seem to work anymore. Any reason for this and how can I fix it?
In addition, the "notice popup display time" does not work either.
Brian
13 years 5 months ago #100297 by Mohamed Thelji
Hi Brian,
Are you using any SEF module ? If yes, can you turn it off and try again ?
13 years 5 months ago #100310 by briand
Hi Mohamed,
No I dont use any SEF I have JCH optimise and I turned that off but that did not solve the problem. The only changes I have made are Hikashop configurations. Do you have any other suggestions?
Brian
13 years 5 months ago #100318 by Mohamed Thelji
Could you give me a link to your website ? it will probably help me to understand from where your problem is coming from ?
13 years 5 months ago #100323 by briand
Hi Mohamed,
Please see below, it also does the same thing with the "add to wishlist" too.
www.regenervite.com/shop-online
Brian
13 years 5 months ago #100331 by Mohamed Thelji
Hi Brian,
I tested the add to cart popup through your website, and it seems like you are using a SEF module, so can you check it through your back end please ? :).
13 years 5 months ago #100335 by briand
Hi Mohamed,
Sorry did not realise you meant the SEF in global configs, thanks.
Brian
13 years 5 months ago #100336 by briand
Hi Mohamed,
Does that mean I cannot use SEF URL's at all?
Brian
13 years 5 months ago #100358 by Mohamed Thelji
No, I just wanted to know if it was caused by your SEF module, so can you test it without any SEF ?
13 years 5 months ago #100433 by briand
Hi Mohamed,
Tested popup window function with SEF module off and it works, both add to cart and add to wishlist. So what is the solution to using the popup function in Hikashop and the SEF module in Joomla. Curiously, there was not conflict when I first selected the popup option and SEF already was on.
Brian
13 years 5 months ago #100541 by Mohamed Thelji
Ok, so the problem must be coming from your cart module, Can you give me a temporary access to your back-end through Private Message ?
13 years 5 months ago #100586 by briand
Hi Mohamed,
Your login has been sent to you using private messaging.
Brian
13 years 5 months ago #101015 by Mohamed Thelji
I don't have the Rights :
- to Enable/disable the SEF through your Joomla configuration
- to access to your Hikashop configuration
And I need it to understand how your website react with the SEF module putted ON and OFF.
13 years 5 months ago #101085 by briand
You now have super admin status
Brian
13 years 5 months ago #101494 by nicolas
I have just sent you an email regarding this issue.
13 years 5 months ago #101611 by briand
Unfortuneately, the upload did not work. The following events occurred:
Uploaded package
enabled SEF URL
tested ajax option worked a couple of time and then stopped.
When the failure occurs the item is still loaded into the cart but when I select add to wishlist I get the error message and no products gets added to the wishlist. In addition, when the popup window did work there was a problem whereby if I selected add to cart button the add to wishlistoptions appeared in the popup.
Brian
13 years 5 months ago #101903 by Xavier
Had you edited the view "checkout / notice" before the update ?
If it is, can you save the content of this view in an external file, delete the customizations (clicking on the dustbin in the views listing), see if it's working fine, and put back your customizations on the new view.
13 years 4 months ago #101929 by Xavier
Thanks to disable the option "Use AJAX when possible for add to cart button" and replace the "updatecart()" function in "administrator/components/com_hikashop/controllers/product.php" by:
function updatecart(){ $app = JFactory::getApplication(); $product_id = (int)JRequest::getCmd('product_id',0); $module_id = (int)JRequest::getCmd('module_id',0); $cart_type = JRequest::getString('hikashop_cart_type_'.$product_id.'_'.$module_id,'null'); if($cart_type == 'null') $cart_type = JRequest::getString('cart_type','cart'); $cart_type_id = $cart_type.'_id'; // Sometimes >> getUserState / getInt if(JRequest::getInt('cart_id',0,'GET') != 0){ $cart_id = JRequest::getInt('cart_id',0,'GET'); }else{ $cart_id = $app->getUserState(HIKASHOP_COMPONENT.'.'.$cart_type_id,0); } //if "add to" from the cart or wishlist $addTo = JRequest::getString('add_to',''); if($addTo != ''){ $from_id = $cart_id; if($addTo == 'cart') JRequest::setVar('from_id',$cart_id); $cart_id = $app->getUserState(HIKASHOP_COMPONENT.'.'.$addTo.'_id',0); $cart_type_id = $addTo.'_id'; JRequest::setVar('cart_type', $addTo); }else{ JRequest::setVar('cart_type', $cart_type); } //JRequest::setVar('wishlist_id',JRequest::getInt('wishlist_id','0')); JRequest::setVar($cart_type_id, $cart_id); $char = JRequest::getString('characteristic',''); if(!empty($char)){ return $this->show(); }else{ $tmpl = JRequest::getCmd('tmpl','index'); $add = JRequest::getCmd('add',''); if(!empty($add)){ $add=1; }else{ $add=0; } if(empty($product_id)){ $product_id = JRequest::getCmd('cid',0); } $cart_product_id = JRequest::getCmd('cart_product_id',0); $quantity = JRequest::getInt('quantity',1); $class = hikashop_get('class.cart'); if(hikashop_loadUser() != null || $cart_type != 'wishlist'){ if(!empty($product_id)){ $type = JRequest::getWord('type','product'); if($type=='product'){ $product_id=(int)$product_id; } $status = $class->update($product_id,$quantity,$add,$type); }elseif(!empty($cart_product_id)){ $status = $class->update($cart_product_id,$quantity,$add,'item'); }else{ $formData = JRequest::getVar( 'item', array(), '', 'array' ); if(!empty($formData)){ $class->update($formData,0,$add,'item'); }else{ $formData = JRequest::getVar( 'data', array(), '', 'array' ); if(!empty($formData)){ $class->update($formData,0,$add); } } } } $app->setUserState(HIKASHOP_COMPONENT.'.'.$cart_type.'_new', '1'); if(@$class->errors && $tmpl!='component'){ if(!empty($_SERVER['HTTP_REFERER'])){ if(strpos($_SERVER['HTTP_REFERER'],HIKASHOP_LIVE)===false && preg_match('#^https?://.*#',$_SERVER['HTTP_REFERER'])) return false; $app->redirect($_SERVER['HTTP_REFERER']); }else{ echo '<html><head><script type="text/javascript">history.back();</script></head><body></body></html>'; exit; } } $app->setUserState( HIKASHOP_COMPONENT.'.shipping_method',''); $app->setUserState( HIKASHOP_COMPONENT.'.shipping_id',''); $app->setUserState( HIKASHOP_COMPONENT.'.shipping_data',''); $app->setUserState( HIKASHOP_COMPONENT.'.payment_method',''); $app->setUserState( HIKASHOP_COMPONENT.'.payment_id',''); $app->setUserState( HIKASHOP_COMPONENT.'.payment_data',''); $config =& hikashop_config(); $checkout = JRequest::getString('checkout',''); if(!empty($checkout)){ global $Itemid; $url = 'checkout'; if(!empty($Itemid)){ $url.='&Itemid='.$Itemid; } $url = hikashop_completeLink($url,false,true); $this->setRedirect($url); } else if($cart_type == 'wishlist'){ if(hikashop_loadUser() == null){ $app->enqueueMessage('LOGIN_REQUIRED_FOR_WISHLISTS'); $stay = 0; $url = JRequest::getVar('return_url',''); if(!empty($url)){ $url=base64_decode(urldecode($url)); } $url = str_replace('&popup=1','',$url); }else{ $redirectConfig = $config->get('redirect_url_after_add_cart','stay_if_cart'); $url=''; $stay = 0; switch($redirectConfig){ case 'ask_user': $url = JRequest::getVar('return_url',''); if(!empty($url)){ $url=base64_decode(urldecode($url)); } $url = str_replace('&popup=1','',$url); if(JRequest::getInt('popup',0) || JRequest::getInt('quantity',0)){ if(strpos($url,'?')){ $url.='&'; }else{ $url.='?'; } $url.='popup=1'; } JRequest::setVar('cart_type','wishlist'); $app->setUserState( HIKASHOP_COMPONENT.'.popup_cart_type','wishlist'); break; case 'stay': $stay = 1; break; //$stay = 1; && $url =''; case 'checkout': break; //$stay = 0; && $url =''; case 'stay_if_cart': $module = JModuleHelper::getModule('hikashop_cart',false); if($module != null){ $stay = 1; } break; default: break; } } if(empty($url)){ global $Itemid; if(isset($from_id))$cart_id = $from_id; if(JRequest::getInt('new_'.$cart_type.'_id',0)!= 0 && JRequest::getInt('delete',0) == 0)$cart_id = JRequest::getInt('new_'.$cart_type.'_id',0); $cart = $class->get($cart_id,false,$cart_type); if(!empty($cart) && (int)$cart_id != 0){ $url = 'cart&task=showcart&cart_type=wishlist&cart_id='.$cart_id.'&Itemid='.$Itemid; }else{ $url = 'cart&task=showcarts&cart_type=wishlist&Itemid='.$Itemid; } $url = hikashop_completeLink($url,false,true); } if($stay == 0){ if(strpos($url,HIKASHOP_LIVE)===false && preg_match('#^https?://.*#',$url)) return false; $this->setRedirect($url); }else{ echo '<html><head><script type="text/javascript">history.back();</script></head><body></body></html>'; exit; } }else{ $url = JRequest::getVar('return_url',''); if(empty($url)){ $url = JRequest::getVar('url',''); $url = urldecode($url); }else{ $url = base64_decode(urldecode($url)); } $url = str_replace('&popup=1','',$url); if(empty($url)){ global $Itemid; $url = 'checkout'; if(!empty($Itemid)){ $url.='&Itemid='.$Itemid; } $url = hikashop_completeLink($url,false,true); } if($tmpl=='component'){ //display cart module content $js =''; jimport('joomla.application.module.helper'); global $Itemid; if(isset($Itemid) && empty($Itemid)){ $Itemid=null; JRequest::setVar('Itemid',null); } $module = JModuleHelper::getModule('hikashop_cart',false); $config =& hikashop_config(); $params = new HikaParameter( @$module->params ); if(!empty($module)){ $module_options = $config->get('params_'.$module->id); } if(empty($module_options)){ $module_options = $config->get('default_params'); } foreach($module_options as $key => $optionElement){ $params->set($key,$optionElement); } if(!empty($module)){ foreach(get_object_vars($module) as $k => $v){ if(!is_object($v)){ $params->set($k,$v); } } $params->set('from','module'); } $params->set('return_url',$url); hikashop_getLayout('product','cart',$params,$js); return true; }else{ $config =& hikashop_config(); if(JRequest::getInt('popup',0) || (@JRequest::getInt('quantity',0) && $config->get('redirect_url_after_add_cart','stay_if_cart') == 'ask_user')){ if(strpos($url,'?')){ $url.='&'; }else{ $url.='?'; } $url.='popup=1'; } if(strpos($url,HIKASHOP_LIVE)===false && preg_match('#^https?://.*#',$url)) return false; $this->setRedirect($url); return false; } } } }
13 years 4 months ago #101950 by briand
Added the code, turned on the ajax option again, worked for a while now works sometimes and not other. Shows "added to wishlist" when add to cart button is pressed. When no Ajax window appears products are still added to the cart and I remain on the page.
13 years 4 months ago #101965 by Xavier
So without Ajax, it's working fine ? The popup is displayed, products are added and you stay on the same page, right ?
Time to create page: 0.351 seconds
