Cart pop-up window does not display
13 years 5 months ago #100339 by anusia
HI, I have seen another post about this and tried to solve it myself, but cannot seem to find a solution.
I even downloaded the JQuery Easy plugin recommended, but that did not do anything either.
The site: 50.97.105.145/~mandecki/index.php/produc...affle-pack-400-units
when I click on add to Cart does not display the pop-up window at all.
Any suggestions will be appreciated.
Thank you,
-Anna
13 years 5 months ago - 13 years 5 months ago #100354 by Mohamed Thelji
Can you show me how did you configured your add to cart button ("Hikashop->System->Configuration->'Main'->'Cart'") through some screenshots ?
Thank you :).
Last edit: 13 years 5 months ago by Mohamed Thelji.
13 years 5 months ago #100374 by anusia
I have these 2 screenshots, please see attached. Am I missing another configuration place maybe?
Thank you,
-Anna
13 years 5 months ago #100386 by anusia
I see that I got an error when I tried to attach files before.
Attaching the correct file extension now.
13 years 5 months ago #100622 by anusia
Can anybody help me with this issue please? I need a pop-up window but for some reason it does not work.
Thank you!
13 years 5 months ago #100624 by Mohamed Thelji
Did you set the "Use AJAX when possible for add to cart buttons" to YES through "Hikashop->System->Configuration->'Main'" ? if not, can you do it and test your add to cart button again ?
The following user(s) said Thank You: anusia
13 years 5 months ago #100646 by anusia
OMG, that was it, thank you so much!
Time to create page: 0.205 seconds
