Custom product fields - add to cart
13 years 4 months ago #103238 by momentis
I have found and read this post about including a custom field in an add-to-cart link:
www.hikashop.com/en/forum/2-general-talk...-product-fields.html
In the post, it describes using a link such as this to add a product to the cart:
http://myshop.com/index.php?option=com_hikashop&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id=887&data[item][tracking_id]=123456
If I have two custom fields, can I create the URL to add both of these fields? So, can I do the following:
http://myshop.com/index.php?option=com_hikashop&ctrl=product&task=updatecart&quantity=1&checkout=1&product_id=887&data[item][tracking_id]=123456&data[item][custom_desc]='product description'
so that both custom fields are passed to the cart?
13 years 4 months ago #103239 by momentis
And, as a follow-up, how would I add these two fields to display in the cart?
13 years 4 months ago #103248 by momentis
I found that I can insert both custom fields with one URL, so that part of my question has been answered.
When I add the product to the cart, the two custom fields appear on top of one another, like:
Product ID: 1081-17HT
Product Description: DISS Fittings; DISS Body Adaptors; Body Adaptor, Hose Bard with Hand Grip Collar; Carbon Dioxide
Is there a way to edit the cart itself, so that these two fields appear next to each other? Basically, I want to replace existing columns in the cart (image, product name, price) with the custom fields Product ID and Product Description. Is this possible?
13 years 4 months ago #103262 by momentis
I am going to open a new topic on this issue. This one has been answered.
13 years 4 months ago #103279 by Jerome
Ok.
Time to create page: 0.163 seconds
