Product quantity box is missing
13 years 4 months ago #103304 by dyvymtvar
I don't know if this post should be here.
In product wiew and in checkout there was a box with + and - where you could choose what amount of product do you want. Now this box isn't it. I'm not sure when or how it happened, I see it today.
I searched in hikashop configuration but I don't find an option for this.
It can be because product is unlimited? but in limited products it isn't too.
Any suggestions?
13 years 4 months ago #103315 by Jerome
You changed an option in the HikaShop backend: "Display the quantity field on the product page"
The following user(s) said Thank You: dyvymtvar
13 years 4 months ago #103646 by dyvymtvar
Thanks Jerome.
I searched that option in configuration but I didin't see it.
13 years 4 months ago - 13 years 4 months ago #103655 by Jerome
www.hikashop.com/en/support/documentatio...ig.html#main_product
(The screenshot is not up to date but the text is)
Last edit: 13 years 4 months ago by Jerome.
13 years 4 months ago #103701 by dyvymtvar
I solved it before.
I explained to you that previously I had not found the option. Sorry for haven't expressed myself well and thanks again.
Time to create page: 0.154 seconds
