Problem with backend translatuioin
13 years 3 months ago - 13 years 3 months ago #108957 by Rebo2k
I have a problem with a specific backend translation.
All labels with the languahe string "HIKASHOP_YES" and "HIKASHOP_NO" wil be no longer translated in any language.
I have no idear where it comes from.
See the attachment.
Thanks in advance,
René
Last edit: 13 years 3 months ago by Rebo2k.
13 years 3 months ago #108971 by nicolas
It doesn't look like a translation issue but rather like a template CSS issue.
Are you using the default template of the backend of Joomla ? If not, try to switch back to it and it should display fine again.
The following user(s) said Thank You: Rebo2k
13 years 3 months ago #108999 by Rebo2k
Thank you for directing me to the right direction :)
I switched the backend css in the configuration module from Hikashop, from custom to default, saved it and there was no result.
Switched it back to custom and saved it again, and the problem is solved.
Thanks again.
Time to create page: 0.192 seconds
