Can't get products to display to 3rd level
15 years 3 months ago #18378 by FreshIdeas
Please follow this link... .this is the rendering when you click on Shop Online. It displays a master top level categories, click on Breyer and you will see the nice layout of the categories under Breyer...click on any of these categories...no products display, yet there are products THERE.
Now, in the menu tree to the LEFT and in the Main menu...if I start at Breyer, I get the display of categories and I click on the of these categories, I get to the product listings.
What am I missing?
when I try to use the 1st level display, all subcategories, it breaks the layout..by trying to put the list underneath the main category into 2 columns...randomly.
Example -- click on EXAMPLE to the LEFT.
15 years 3 months ago #18393 by nicolas
That's because you unpublished the products listing module from the "associated modules" option of your menu's hikashop options. You need to go back in the menu Display->content menus, edit your menu 808 and publish a products listing module in the associated modules option.
Regarding the listings of sub categories in categories listings, that's something we improved in the latest version of HikaShop. If you update HikaShop and take the new CSS parts added for that into your custom CSS that should help fix the problems.
15 years 3 months ago #18405 by FreshIdeas
Thanks! That fixed the first part!
I upgraded to 1.5.1 and it did NOT fix the layout issue on the 2nd part.
15 years 3 months ago #18410 by nicolas
Great. Now just add the CSS:
.hikashop_category_list {
display: inline-block;
text-align: left;
15 years 3 months ago #18416 by FreshIdeas
sorry to appear so dense, but I WHERE do I add this in the CSS? I added it here (new code in blue) and the result did not change.
.hikashop_category_right_part{
padding-left:1px;
.hikashop_category_list_item, .hikashop_product_list_item{
float:left;
text-align: left;
.hikashop_product_list{
display: inline;
list-style-type: none;
15 years 3 months ago #18423 by nicolas
That worked. Now the list of category names are inside the white zone on my end.
You should also remove the code below so that you don't get several items on the same line:
.hikashop_category_list_item, .hikashop_product_list_item {
float: left;
15 years 3 months ago #18425 by FreshIdeas
Woot! That worked. Another item off the list!!!
Time to create page: 0.233 seconds
