Modify Layout on product page
14 years 2 months ago - 14 years 2 months ago #56993 by Teto
I use Joomla 2.5.6, Hikashop 1.5.8 and a template generated with Artisteer 3.1
My product page doesn't look very well.
Probably due to some space constraints (the product page has about 750/800 px) the "right part" goes under the "left part".
Is there a way to avoid it?
I would also to customize a little bit the product layout page in order to obtain this result (all the fields alligned on the left). Is it possibile?
I would also like to know if is possible to view the comment in a separate tab?
Thank you so much for your help. :)
Last edit: 14 years 2 months ago by Teto.
14 years 2 months ago #57045 by nicolas
For the right area going under the image, you can look here:
www.hikashop.com/en/forum/4-how-to/48858...t-inconsistency.html
For the price alignement, you can look here:
www.hikashop.com/en/forum/2-general-talk...uct-detail-page.html
For the tabs, you will have to do something similar to this:
www.hikashop.com/fr/forum/4-how-to/52260...on-product-page.html
14 years 2 months ago - 14 years 2 months ago #57086 by Teto
Thank you as always, with your help everything seems simple also for me!!!
I was able to modify the first 2 things but I have some problem with the last one.
I modified the product / show_default.php as follow
<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part">
{tab=Tab Title 1}
<div id="hikashop_product_description_main" class="hikashop_product_description_main">
<?php
echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description));
</div>
<span id="hikashop_product_url_main" class="hikashop_product_url_main">
<?php
if (!empty ($this->element->product_url)) {
echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>');
</span>
{tab=Tab Title 2}
<?php
$this->setLayout('show_block_product_files');
echo $this->loadTemplate();
<div id="hikashop_product_vote_listing" class="hikashop_product_vote_listing">
<?php
if($this->params->get('show_vote_product')){
$js = '';
$params = null; //Params already existing in the previous getLayout('vote', ...)
echo hikashop_getLayout('vote', 'listing', $params, $js);
</div>
<div id="hikashop_product_vote_form" class="hikashop_product_vote_form">
<?php
$js = '';
$params = null;
echo hikashop_getLayout('vote', 'form', $params, $js);
</div>
{/tabs}
</div>
i also modified the product / show.php as follow
<form action="<?php echo hikashop_completeLink('product&task=updatecart'); ?>" method="post" name="hikashop_product_form" enctype="multipart/form-data">
<?php
$this->setLayout($this->productlayout);
Old code - Stefano
echo JHTML::_('content.prepare',$this->loadTemplate());
but unfortunately it doen't work, did i miss something?
14 years 2 months ago #57164 by nicolas
I would say that the problem is that the second view file modification you made (in product/show.php) was not for the correct template. Could you double check that ?
14 years 2 months ago - 14 years 2 months ago #57191 by Teto
I checked the situation and I confirm I modified the right template "templatesemplicev3".
I thought it depends by the Template (it is a custom template made with Artisteer 3.1) but with the default Joomla template (Beez2) I have the same problem.
Do you have other ideas?
If you want I may privately send you the URL, username and password to check the site backend.
14 years 2 months ago #57268 by nicolas
Yes. Please provide that via our contact form with a link to that thread:
www.hikashop.com/en/contact-us.html
14 years 2 months ago #57308 by Teto
Thank you really much! :)
I sent to you all the information needed.
I'm really curious to know the reason because it doesn't work.
14 years 2 months ago #57379 by nicolas
You didn't install and publish the tabber plugin:
extensions.joomla.org/extensions/news-di.../articles-tabs/14493
14 years 2 months ago #57382 by Teto
I apologize, I hadn't done the most important thing... :blush: :blush: :blush:
Thanks a lot
14 years 1 month ago - 14 years 1 month ago #59737 by Teto
Hello nicolas
do you think is possbile to move the "specificatons fields" to a separate TAB?
Could you indicate what piece of code I have to move/change?
Could you also indicate if is possible to move the small product image at the right of the main picture?
Thank you
Last edit: 14 years 1 month ago by Teto.
14 years 1 month ago #59799 by nicolas
That's the code used to display the specifications area in your view file :
if(!empty($this->fields)){
$this->setLayout('show_block_custom_main');
Just move it inside your tab tags with potentially <?php and ?> tags around it and it will be in the tabs.
14 years 1 month ago - 14 years 1 month ago #59893 by Teto
Thank You!!!
I did it, I also had to move that part in the bottom area B)
<?php // Stefano Start - Le 5 righe di cui sopra sono state spostate qui ed è stata aggiunta la stringa per abilitare la TAB?>
<?php
?> {tab=Caratteristiche|grey} <?php
<?php // Stefano End ?>
I'm falling in love with Hikashop!!! :laugh: :laugh:
Do you know if is possible to move the small picture of the product to the right of the image? (see my previous message).
Thanks as usual! :cheer: :cheer:
14 years 1 month ago #59975 by nicolas
You can do that with CSS. You might need to adapt the values a bit but you should be able to do it with that CSS:
.hikashop_main_image_div{
width: 60%;
float: left;
.hikashop_small_image_div{
width: 20%;
float: right;
14 years 1 month ago - 14 years 1 month ago #60055 by Teto
Great!!!!! :laugh: :laugh:
I swear this is my last question...
how could I set a fix width for the name of the custom fields?
I tried to insert a margin in .hikashop_product_custom_name but the space is different between the varoius products
.hikashop_product_custom_name{
font-weight:bold;
/* Stefano Start */
/* Spazi per caratteristiche */
margin-right:50px;
/* Stefano End */
I would like to have the same width and different height depending on the content of the relative field.
14 years 1 month ago #60126 by nicolas
I think that you should use something like that CSS:
#hikashop_product_custom_info_main td.key{ width 100px; }
14 years 1 month ago #60158 by Teto
Thank you, unfortunately it works only partially.
when you set a width the system automatically splits the table in 2 parts of the same width.
I tried to increase/decrease the pixels and also to use the % but it isn't possible to set the left part and the right part with different width.
Attachment Example.png not found
14 years 1 month ago #60232 by nicolas
Can you give a link to that page so that we can see that ?
14 years 1 month ago - 14 years 1 month ago #60256 by Teto
www.madeinvino.com/index.php/la-nostra-c...-fattoria-gessi.html
the web site is www.madeinvino.com
go to "La nostra cantina"
and the choose a product.
thanks
14 years 1 month ago #60308 by nicolas
You added the CSS:
#hikashop_product_custom_info_main td{
border-bottom: 1px solid #CCC;
width: 100px;
but I told you to add:
#hikashop_product_custom_info_main td.key {
width: 100px;
That's why it's not working like you want.
14 years 1 month ago #60341 by Teto
.... :blush:
Thank you!
Time to create page: 0.344 seconds
