- Thank you received: 77
Block carousel isn't visible in module settings
9 years 6 months ago #264500
by almika
Block carousel isn't visible in module settings was created by almika
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.3.18
Block carousel isn't visible in module settings "Hikashop Options".
Business version, localhost.
Best regards,
Best regards,
9 years 6 months ago #264507
Replied by nicolas on topic Block carousel isn't visible in module settings
I'm not able to reproduce the problem with the 3.0.1.
The only way is to have the Starter or the Essential edition installed.
Can you check your version in the HikaShop configuration and make sure that you've installed the Business edition ?
Otherwise, open the browser javascript console. You might have a javascript error on the page (related to a conflict with another extension, or something like that) which prevents the javascript of HikaShop from initializing properly.
9 years 6 months ago #264614
by almika
Replied by almika on topic Block carousel isn't visible in module settings
I checked the version. It's Business.
There is the warning "JQmigrate migrate is installed version 1.4.1" in the inspector of Mozilla Firefox, Opera, IE.
Only Joomla and Hikashop are installed.
And I have the same problem for Hikashop Business 2.6.4 and Joomla 3.6.5. Both on hosting and on the local machine.
Best regards,
Best regards,
9 years 6 months ago #264615
by Jerome
Replied by Jerome on topic Block carousel isn't visible in module settings
Please select the layout "Div" and not the layout "Inherit".
Even if the "inherit" is configured to used "div", you have to select manually that specific value to see the carousel setting.
The following user(s) said Thank You: almika
9 years 6 months ago #264654
by almika
Thank you, Jerome!
It works!
Best regards,
It works!
Best regards,
Time to create page: 0.219 seconds
