product option problem in cart and checkout
11 years 2 months ago - 11 years 2 months ago #208076 by kaya
-- HikaShop version -- : 2.x.x
-- Joomla version -- : 2.5
Hi Dear
I have a problem with product option when add to cart and go to checkout page.
when add option for a product my add to cart not work correct. when my product have option and click add to cart only add another product from same category to my cart. What is my problem? when my product not have option add to cart work correct but when have option not work correct.
Last edit: 11 years 2 months ago by kaya.
11 years 2 months ago #208081 by nicolas
This sounds like a problem with the customization of the product page.
Could you provide a link to the product page with the issue so that we could analyze the situation ?
The following user(s) said Thank You: kaya
11 years 2 months ago #208151 by kaya
Hi Dear Nicolas
We created custom template please say me with part I checked for this. I cann't provide a link now.
thank you
11 years 2 months ago #208183 by Mohamed Thelji
Note that without directly testing it, we won't be able to understand your issue and help you. Also, can you test it without any customization, or with a default Joomla template for example ?
11 years 2 months ago #208301 by kaya
Hi Dear Mohamed Thelji
We create custom joomla template and customization some part of hikashop product page.
Can you say me what part is for product options?
11 years 2 months ago #208379 by nicolas
The first thing to check are the files in the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/
Try to rename temporarily the folder via FTP and see if that fixes the issue. If so, then there is a problem with one of the files in that folder.
Rename each one, one by one and test if it works in order to find which one is creating the problem.
If renaming the product folder doesn't help, then the problem is elsewhere. I unfortunately cannot tell you where as we don't know ourselves. That's why I had asked a link to the page as otherwise we're looking for a needle in a haystack.
Time to create page: 0.197 seconds
