Add to Cart pop up box does not display
10 years 11 months ago #218011 by wolfhome
-- url of the page with the problem -- : wolfhomeny.com/index.php/wool-chairs/pro...omet-grey-wool-chair
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.3.25
-- Browser(s) name and version -- : chrome, firefox (latest)
Hi, since upgrading to the newest versio of Hikashop a few days ago
the add to cart pop up window does not show up anymore when i add an item to cart.
the item does get added to the cart, but the window just doesnt show up anymore.
10 years 11 months ago #218026 by Xavier
Please check the settings of the option "After a product is added to the cart" in Configuration > Main > Cart.
If it is correctly set on "Stay and display a popup notice" so on frontend check if there is no javascript errors thanks to the browser console.
Else you can too try another popup system in Configuration > Display > General display options.
10 years 11 months ago #218121 by wolfhome
i checked and the setting is fine
now the add to cart button doesn't even work at all, when you click nothing happens, at least yesterday it was adding to the cart without displaying the pop up
I havn'e made any changes form when that was working yesterday to now when i just tried it again.
on top of that none of my characteristics are working AGAIN
I had this exact same problem last time there was an update and had to spend so much time trying to fix it.
10 years 11 months ago #218148 by nicolas
I've checked your link and the whole javascript of HikaShop is missing from the header of the page. That's why the characteristics, the add to cart and the popup don't work since they require the javascript of HikaShop to be present.
It doesn't seem to be related to the update but to a third party extension on your website.
I've never seen that. It's as if something on your website had stripped it away.
Could you try to disable any cache or optimization system, and switch to the default tempalte of Joomla. Does it work fine then ?
10 years 11 months ago #218156 by wolfhome
I changed to default template and it still down't work
it seems maybe the characters work, but i'm not sure because when i click on one it does't change the image picture like it's suppsed to but it stays selected
the add to cart pop up doesn't work still though.
I haven't installed any other extensions in at least a month, maybe longer.
i don;t think i even updated anything recently.
10 years 11 months ago #218522 by nicolas
Well, I can always offer you to downgrade and see if that helps.
Use our contact form to request the install package of the version you had before and install it on your website. That will perform the downgrade. I don't see why that would fix anything, but it's worth trying.
Time to create page: 0.196 seconds
