Help with empty cart in multi language site
10 years 1 week ago #250991 by MarioMagno
Hello everyone,
my compliments for support team.
I have one issue to submit to all of you:
I've inserted a code:
<input type="submit" class="button" name='EMPTY_CART' value="Svuota carrello" onclick="window.location='<?php echo hikashop::completeLink('product&task=cleancart&return_url='. urlencode(base64_encode('index.php?lang=it'))); ?>';return false;"/>.
and works.
But I have a multilanguage site. So, in this way I do not have a different sentences (Empty cart) in all of languges.
Can you hel me please?
Thanks in advance
10 years 6 days ago #250993 by nicolas
You need to change the piece:
<?php $lang = JFactory::getLanguage(); $locale=strtolower(substr($lang->get('tag'),0,2)); echo hikashop::completeLink('product&task=cleancart&return_url='. urlencode(base64_encode('index.php?lang='.$locale))); ?>
10 years 6 days ago - 10 years 6 days ago #251033 by MarioMagno
nicolas wrote: Hi,
thanks for your quick reply, but unfortunately it doesn't work.
It shown always the same label "Empty Cart" in all languages (maybe caused from input string: input type="submit" class="button" name='EMPTY_CART' value="Svuota carrello" ... )?
Mario
Last edit: 10 years 6 days ago by MarioMagno.
10 years 6 days ago #251054 by nicolas
I thought that the issue was with the lang parameter not the name of the button.
For the name of the button, you can use such code:
<?php echo JText::_('EMPTY_CART'); ?>
And then add a translation override :
EMPTY_CART="Empty cart"
10 years 5 days ago #251145 by MarioMagno
nicolas wrote: I thought that the issue was with the lang parameter not the name of the button.
Ok, but where can I write the piece of code you mentioned?
Maybe I can write like this:
10 years 5 days ago #251149 by nicolas
As I said, you need to replace the name of the button by that code.
So:
<input type="submit" class="button" name='<?php echo JText::_('EMPTY_CART'); ?>' value="<?php echo JText::_('EMPTY_CART'); ?>" onclick="window.location='<?php $lang = JFactory::getLanguage(); $locale=strtolower(substr($lang->get('tag'),0,2)); echo hikashop::completeLink('product&task=cleancart&return_url='. urlencode(base64_encode('index.php?lang='.$locale))); ?>';return false;"/>.
10 years 3 days ago #251283 by MarioMagno
Thank you very much!
Time to create page: 0.207 seconds
