- Thank you received: 12
Control panel is not visible
4 years 6 months ago #340488
by chli
Control panel is not visible was created by chli
4 years 6 months ago #340491
by chli
Replied by chli on topic Control panel is not visible
Okay, i found the solution:
Wert: no
Test: your Information xxxxxx
That`s it.
Unfortunately, there is no description of this in the help.
Wert: no
That`s it.
4 years 6 months ago #340492
Replied by nicolas on topic Control panel is not visible
I'm not sure what your goal is.
Custom fields of the table "order" can only be selected/inputed by the user during the checkout process. Once the order is created, he can see the custom fields filled if you allow for that, but he cannot modify them. Only you can do it from the backend.
So if your question is that you don't see the custom field during the checkout process, then please check your Checkout workflow, under the Checkout tab of the HikaShop configuration and make sure you have the "Fields" view added with that custom field selected.
If your question is that you want the customer to select/input something on his order details page, after the checkout is completed, then there is no easy solution. It would require some development to allow for that.
4 years 6 months ago #340500
by lousyfool
If I may jump in: the German language stuff in the OP's screenshot is telling me that what they really want is a checkbox (or two) for customers to confirm their agreement with terms & conditions etc before finishing checkout.
So, dear OP, have a look at this: www.hikashop.com/forum/7-german/903667-z...errufsbelehrung.html
No need to deploy a custom "order" field.
Replied by lousyfool on topic Control panel is not visible
nicolas wrote: I'm not sure what your goal is.
4 years 6 months ago #340513
by chli
Hi there,
As already written, I was able to solve the problem myself in the meantime. Thank you Nicolas.
And also thanks to lousyfool for pointing out the ready-made option of accepting the terms and conditions.
Time to create page: 0.160 seconds
