- Thank you received: 2
Category selection problem with existing products
10 years 7 months ago - 10 years 7 months ago #231193
by spoonbow
It's amazing how the omission of a semicolon can absolutely ruin an otherwise pleasant evening.
Category selection problem with existing products was created by spoonbow
SOLVED - This was a browser cache issue in Chrome. Clearing the cache resolved the problem.
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.5
I'm having a strange problem with category selection. On an existing product, clicking in the Category field brings up a selection explorer that doesn't match the current structure of the categories. If I begin typing in the name of the desired category in the Category field, then and only then does it show up in the selection explorer. I have attached a graphic illustrating the issue. Center top in the image is an inset with the Category structure, the left side of the image shows the explorer I see when clicking in the Category field, right side shows the result of typing the name of the category. I've cleared cache, logged out and back in, rebuilt categories, and the behavior persists.
Last edit: 10 years 7 months ago by spoonbow. Reason: Solution found and added to original post
10 years 7 months ago #231206
Replied by nicolas on topic Category selection problem with existing products
I've never seen that.
If you don't have yet products configured, you can empty the hikashop_category table and the hikashop_product_category table via your phpmyadmin and then install the HikaShop package.
That will reset the categories to their default structure and you can then add the categories again. It should then hopefully work properly.
10 years 7 months ago - 10 years 7 months ago #231286
by spoonbow
Replied by spoonbow on topic Category selection problem with existing products
Weird, right? The DB tables look good - No orphaned/dissociated entries. As a matter of fact, I don't even see the old "Beer" category in the categories table. Where does the data for the category explorer on the product edit screen come from? Is it possible it's cached somewhere? I don't have too many products entered yet, but I'd rather not repeat the exercise of entering them again if I don't have to.
Incidentally, the problem exists with new products as well. For whatever reason I was thinking that Categories were displaying properly for new products - I was mistaken...
Matt
Matt
Last edit: 10 years 7 months ago by spoonbow. Reason: Additional information
10 years 7 months ago #231299
by spoonbow
OK, looks like Chrome cached the result of the ".../administrator/index.php?option=com_hikashop&ctrl=category&task=getTree&category_id=2" call two days ago and has been using it for subsequent calls. Did a search of my cache and found the following, which shows the old "Beer" category. Accessed the edit product page with a clean browser cache and the proper categories showed up.
Matt
Matt
10 years 7 months ago #231313
Try to add the line:
hikashop_nocache();
after the line:
function getTree() {
in the file administrator/components/com_hikashop/controllers/category.php
That should force the browser to not cache the data for the category explorer and thus you should not have the problem anymore.
hikashop_nocache();
after the line:
The following user(s) said Thank You: spoonbow
Time to create page: 0.158 seconds
