Products sometimes not added to cart
- Squashtoppertje
10 years 7 months ago #229320
by Squashtoppertje
Products sometimes not added to cart was created by Squashtoppertje
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.3.10
I'm using the listing_table to show products in rows. Because it is a long list I also wanted to place the Add to cart-button at the top of the page, instead of only at the bottom.
So i copied the code of the button to the top of listing_table.php. But it seems that occasionally, maybe only the first time someone uses this button, the products are not added to the cart. Everything seems to go right, but if you go to the cart it is empty. People complain this is happening, I only could reproduce it one time. So not sure where to look.
Have any of you got any idea what could be the issue here?
The code I placed at the top of listing_table.php is:
Thanks!
<?php if ($this->config->get('show_quantity_field')>=2) {
$this->ajax = 'if(hikashopCheckChangeForm(\'item\',\'hikashop_product_form_'.$this->params->get('main_div_name').'\')){ return hikashopModifyQuantity(\'\',field,1,\'hikashop_product_form_'.$this->params->get('main_div_name').'\'); } return false;';
$this->row = null;
$this->row->product_quantity = -1;
$this->row->product_min_per_order = 0;
$this->row->product_max_per_order = -1;
$this->row->product_sale_start = 0;
$this->row->product_sale_end = 0;
$this->row->prices = array('filler');
$this->setLayout('quantity');
echo $this->loadTemplate();
if(!empty($this->ajax) && $this->config->get('redirect_url_after_add_cart','stay_if_cart')=='ask_user'){ ?>
<input type="hidden" name="popup" value="1"/>
<?php } ?>
<input type="hidden" name="hikashop_cart_type_0" id="hikashop_cart_type_0" value="cart"/>
<input type="hidden" name="add" value="1"/>
<input type="hidden" name="ctrl" value="product"/>
<input type="hidden" name="task" value="updatecart"/>
<input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/>
</form>
<?php }
if(in_array($pagination,array('bottom','both')) && $this->params->get('show_limit') && $this->pageInfo->elements->total){ $this->pagination->form = '_bottom'; ?>
<form action="<?php echo hikashop_currentURL(); ?>" method="post" name="adminForm_<?php echo $this->params->get('main_div_name').$this->category_selected;?>_bottom">
<div class="hikashop_products_pagination hikashop_products_pagination_bottom">
<?php echo $this->pagination->getListFooter($this->params->get('limit')); ?>
<span class="hikashop_results_counter"><?php echo $this->pagination->getResultsCounter(); ?></span>
</div>
<input type="hidden" name="filter_order_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->value; ?>" />
<input type="hidden" name="filter_order_Dir_<?php echo $this->params->get('main_div_name').$this->category_selected;?>" value="<?php echo $this->pageInfo->filter->order->dir; ?>" />
<?php echo JHTML::_( 'form.token' ); ?>
</form>
<?php } ?>
Thanks!
- Thank you received: 1778
10 years 7 months ago #229351
by Mohamed Thelji
Replied by Mohamed Thelji on topic Products sometimes not added to cart
Your issue will depend on where you exactly moved that code on the "listing_table" file, so can you give us more information about it ?
Also, note that it won't work if you have moved these lines above these lines :
If you want to debug your customization, the best solution will probably be to enable the Joomla debug mode and error reporting.
<?php foreach($this->rows as $row){
$this->row =& $row;
- Squashtoppertje
10 years 7 months ago #229408
by Squashtoppertje
Replied by Squashtoppertje on topic Products sometimes not added to cart
Hi Mohamed,
I placed the full code at the top of the page, so right after
I want it to show at the top of the page. To be clear: it works most of the time.
Thanks again.
Thanks again.
10 years 7 months ago #229427
Replied by nicolas on topic Products sometimes not added to cart
That's the problem.
The quantity inputs and the button needs to be inside the <form> and </form> tags.
If you look at the code you gave you can see that it's not the case:
take.ms/xLWsU
The add to cart button is now outside the form tags and the </form> tag should be left at the end of the listing.
take.ms/xLWsU
- Squashtoppertje
10 years 7 months ago #229563
by Squashtoppertje
I'm sorry, I don't understand your answer. The given code is exactly the same as the original code at the bottom of the page of listing_table.php. I only copied it to the top.
But, to take another approach, what do I need to do if I want the button on the top also?
Thanks again!
Thanks again!
10 years 7 months ago #229571
What you did is a good idea, but you need to remove the </form> tag from the code that you copy/paste and you need to put your code after the <form> tag of the view.
That's basically what I hinted at in my previous message.
The following user(s) said Thank You: Squashtoppertje
- Squashtoppertje
10 years 7 months ago #229733
by Squashtoppertje
Thanks, I think I solved it by copying the complete code to after the form-tags. Not completely sure yet, but I will see if any users still got the problem.
This is wat I got now:
</form>
$this->row = null;
<?php } ?>
<?php }
<?php } ?>
Time to create page: 0.197 seconds
