Custom fields for product in order variable
4 years 6 months ago #340633 by tgdkere2
I created a custom field for the product table which I would need in the order variable:
$order_full = $orderClass->loadFullOrder($order->order_id, true, false);
This custom field is also displayed on the frontend.
I need this custom field for the product in the function: onAfterOrderUpdate(&$order, &$send_email)
But the custom field is not available in the order variable.
Why not and how can I add it , so that I can use it in the function onAfterOrderUpdate ???
Thanks and br
Rene
4 years 5 months ago - 4 years 5 months ago #340651 by nicolas
Well, the whole product data in not loaded with the order. That's because this is usually not needed.
You can do this in your code:
$productClass = hikashop_get('class.product); foreach( $order_full->products as $product) { $productData = $productClass->get($product->product_id); echo $productData->xxx; }
where xxx is the column name of your custom field of the table "product".
Last edit: 4 years 5 months ago by nicolas.
The following user(s) said Thank You: tgdkere2
Time to create page: 0.143 seconds
