Changing prices on multiple products
10 years 7 months ago #229356
by skot
Replied by skot on topic Changing prices on multiple products
Hello Xavier and thanks for the answer,
The solution you're proposing is not quite ideal as I would have to change manually hundreds of prices in EUR. Would there be another way to do it? Like exporting all data into csv using mass action, modifying in excel and then re-importing via product/import? The only problem I see is that mass action exports currency IDs as "EUR" "USD" etc... whereas import function needs the currency ID as a number. Or would there be a way to make it work?
Many thanks
Raphael
Many thanks
Raphael
10 years 7 months ago #229368
by Xavier
Replied by Xavier on topic Changing prices on multiple products
Indeed exporting and importing via CSV file is a solution, the currency codes are managed when importing the csv file in the mass actions.
10 years 7 months ago #229490
by skot
So you mean that we can update prices by importing a csv with mass action? I remember having tried that in the past and it didn't work, I had to go through the Products/Import option to import a csv... or maybe this was fixed in the latest update?
10 years 7 months ago #229508
Replied by nicolas on topic Changing prices on multiple products
Yes, it's now possible to update prices with the import of CSV files in the mass action system.
8 years 9 months ago #283863
by tesla
Replied by tesla on topic Changing prices on multiple products
Hello Nicolas,
I need your help!
How to word the text in the operation field of mass update in order to achieve the following:
round(price.prive_value*1.05, 1)
Example: price value = 24.50. Objective with the above formula is to increase it to 25.70 instead of 25.73 which will be the result without round.
Thanks in advance!
I need your help!
Thanks in advance!
8 years 9 months ago #283864
Change the code:
$symbols = array('%','+','-','/','*','(',')');
$symbols = array('%','+','-','/','*','(',')',',');
in the file administrator/components/com_hikashop/classes/massaction.php and that should allow you to use that operation in your mass action.
We'll add that change on our end so let us know how that goes.
Change the code:
Time to create page: 0.262 seconds
