need a credit system. or a how to
12 years 4 months ago #157906 by edocif
-- url of the page with the problem -- : no problem
-- HikaShop version -- : HikaShop [1312231536]
-- Joomla version -- : 3.3
-- PHP version -- : 5.4.2
have a customer that wants to buy a large block of credits. then have it's users come to the site and buy against the credits. is this possible? for example. they pay $10,000.00 then with a coupon or credit code the 10,000 is loaded into the system their users then put that code in on checkout and it deducts the cart total from the 10,000 until empty.
12 years 4 months ago #157912 by lousyfool
Unless I'm completely wrong, that's what Alpha User Points are for. See the link and search for "AUP" here in the forums.
It's a payment system in the first place (good start for what you need), and you can make the points available to users by creating "products" which aren't really any, but the e.g. $10,000 the user pays for it earns them 10,000 points (or whatever "conversion rate" you set), and with those points they can go shopping.
Sure a coupon can be used to subsidise the points purchase, partially or fully.
12 years 4 months ago #157921 by edocif
i will try this thank you
12 years 4 months ago #157910 by Jerome
With the plugins "user points" it is possible to link HikaShop with a point system.
You can link it with the component "Alpha User Points" or to a "user custom field" that you have to call "user_points".
The points plugins are in HikaShop Business.
Here the tutorial about points : www.hikashop.com/support/support/documen...57-using-points.html
Time to create page: 0.274 seconds
