- Thank you received: 8
Order numbers out of sync
- MumsHealth
3 years 11 months ago #345863
by MumsHealth
Order numbers out of sync was created by MumsHealth
-- HikaShop version -- : 4.6.2
-- Joomla version -- : 3.10
We have our Order number format and Invoice number format both set to W{id} so the order and invoice number are the same.
Recently an employee accidentally created an order and then deleted it now the invoice id is always 1 lower than the order id.
For example:
Order number: W600
Invoice number: W599
Why is this the case if we are using W{id} as the format for both? Shouldn't this match the orders ID column?
Thanks,
Nathan
For example:
Order number: W600
Thanks,
Nathan
3 years 11 months ago - 3 years 11 months ago #345865
Replied by nicolas on topic Order numbers out of sync
{id} means {order_id} for the "order number format" and {order_invoice_id} for the "invoice number format".
The order_id is incremented when a new order is created.
The order_invoice_id is incremented when an order is confirmed (usually after a payment).
So if an order is created but not confirmed, the order_id will be incremented but not the order_invoice_id and thus if you use {id} for both formats you'll get a discrepency.
If you want the invoice number format setting to use the order_id, then you need to use {order_id} instead of {id}
Last edit: 3 years 11 months ago by nicolas.
- MumsHealth
3 years 11 months ago #345886
by MumsHealth
Replied by MumsHealth on topic Order numbers out of sync
Thank you very much. That makes sense.
Is there any risk to changing order/invoice number format now? Will it change old old orders or just the future ones?
3 years 11 months ago #345910
It won't change the old orders, only the future ones.
There is no risk.
There is no risk.
The following user(s) said Thank You: MumsHealth
- MumsHealth
3 years 10 months ago #346372
by MumsHealth
Thank you. I forgot to respond to this but it worked!
Time to create page: 0.183 seconds
