- Thank you received: 2
Hybrid Waitlist and Pre-Order possible?
2 years 7 months ago #358813
by yorkits
Hybrid Waitlist and Pre-Order possible? was created by yorkits
-- Joomla version -- : 4.4.1
-- PHP version -- : 8.1.27
Hi Guys,
My client has Waitlist configured, but would like customers to be able to pre-order (and pay for) some special order products. I can see that waitlist can be configured on a product basis, but I don't know if the pre-order plugin can work with certain products. Can you advise me on this possibility please?
Many thanks
Dave
Hi Guys,
Many thanks
Dave
2 years 7 months ago #358814
Replied by nicolas on topic Hybrid Waitlist and Pre-Order possible?
Both can work on the same website.
However, if you set a per order stock for a product, the waitlist will only be available for that product once both the normal stock and the pre order stock are exhausted.
For products without a pre order stock, the waitlist will work normally.
The following user(s) said Thank You: yorkits
2 years 7 months ago #358825
by yorkits
Replied by yorkits on topic Hybrid Waitlist and Pre-Order possible?
Thank you for your quick response. From your reply, it sounds like the pre-order plugin adds a pre-order stock quantity setting so the site owner will need to set a quantity that can be placed on back order. This functionality sounds very flexible and ideal for my client.
Many thanks
Dave
Many thanks
Dave
2 years 7 months ago #358836
Yes, that's precisely what the plugin does.
2 years 7 months ago #358949
by yorkits
Thank you for your clarification. I've bought and installed the plugin.
Time to create page: 0.219 seconds
