- Thank you received: 1
Hikshop Bootsrap settings and Rockettheme
-- HikaShop version -- : 2.4
-- Joomla version -- : 3.4
-- PHP version -- : 5
I have multiple sites being built on older responsive joomla 3.4 Rockettheme templates.
They don't seem to support your bootstrap setting for responsive design. Every time I ennable it the divs break and I see them as stacked li content instead of columns.
Is there a way to globally add the required boostrap javacsript support? I have been override the static layouts with RT grids but that is very time intensive. being that they are one of the biggest template builders and you are one of the biggest ecommerce solutions has anyone else had this issue and what have you suggested to them. i don't see anything from search. I love your product and RTbutt it seems I am doing custom css or rebuilding the html on a regular basis now and feel I must be missing something.
I'm not sure I understand all in your message.
HikaShop is currently just compatible with Bootstrap 2 ; like Joomla 3.4.They don't seem to support your bootstrap setting for responsive design. Every time I ennable it the divs break and I see them as stacked li content instead of columns.
Joomla 3 provide CSS and Javascript from Bootstrap 2, the default backend and default template are using bootstrap 2 for the grid system.
Bootstrap 2 is the official and default grid system in Joomla 3 ; there are an hundred of grid system over the Internet.
But you might see in the different HikaShop views that we are using PHP constants for the grid system, like "HK_GRID_ROW" or "HK_GRID_COL_3" : if you take a look at the HikaShop helper, you will see the base of a dynamic grid 12 system that is still under development but which will be great once finished.
I'm sorry but I don't understand.Is there a way to globally add the required boostrap javacsript support?
getbootstrap.com/getting-started/#download-cdn
I will let you know what happens...LOL
Be careful with the bootstrap version ; "getbootstrap" is for Bootstrap 3, HikaShop and Joomla are using Bootstrap 2.
(but the implémentation of Boostrap 3 is in progress)
Either....
<div class="rt-demo-width-50">
or newer is this.
<div class="gantry-width-block gantry-width-50">
Just be sure your set on your columns. As the percentage is based on how many columns. 50 is 2 column
3 column is 33 four column is 25..etc.
Takes a little time but then it is fully integrated and smooth as butter.
www.hikashop.com/support/forum/2-general...g-media-queries.html
It doesn't require any PHP coding and if you're a web designer, you must be familiar with CSS so that shouldn't be a problem.
As Nicolas said you have to add media queries to apply specific css properties on specific screen size.
To use these media queries, the divs must have classes like "span4" etc.
Here is more documentation about layout customizations:
This is a call we make to break 4 columns into 2 at a specific width. Then down to 1.
You will need to know how to add a custom css file which they can help you with on the RT forum.
@media only screen and (max-width: 1025px){
.hikashop_product_column_1,.hikashop_product_column_2,.hikashop_product_column_3,.hikashop_product_column_4 {
width:50%!important;}
@media only screen and (max-width: 767px) {
.hikashop_product_column_1,.hikashop_product_column_2,.hikashop_product_column_3,.hikashop_product_column_4 {width:100%!important;}
.sprocket-strips-content {min-height: 200px;}
.hikashop_product_characteristics{ display:block; clear:both;}
.hikashop_product_main_image_subdiv{ float: left; width: 30%!important;}
.hikashop_checkout_login{width:100%;}
select{max-width:100%;}
h4.iconstext{ font-size: 15px; display:block; clear:both;}
.margins{ margin: -10px -10px -10px -20px;}
.bullethide{display:none;}
.mobileBreak{display:block; clear:both; line-height:0.3em;}
