- Thank you received: 6
Related Products Go Away When Adding To Cart Main Product
7 years 8 months ago #302439
by fan4chevy
I have Hikashop Business. I want to be able to display related products that customers can add to the main product.
Question 1:
How can I make it so that when the customer adds the main product of interest, they can see the related products to add that as well if they choose. Currently if they add to cart the main then it goes to another page and the related are no longer seen. So they can't add easily both.
Question 2:
The related products are so far down on the page under the description box that it is not easily seen. can it be moved somewhere it can be seen easier?
Question 1:
Question 2:
7 years 8 months ago #302444
Replied by nicolas on topic Related Products Go Away When Adding To Cart Main Product
1. If you want to display "the products related to the products already in the cart" on the checkout, there is a plugin available on our marketplace for that:
www.hikashop.com/marketplace/product/142-checkout-related.html
2. You'll have to edit the files "show" and "show_default" of the "product" view via the menu Display>Views in order to change that.
The related products are displayed by the code:
in the show view file. You can move that in the show_default view file based on where you want it.
<div class="hikashop_submodules" id="hikashop_submodules" style="clear:both">
<?php
if(!empty ($this->modules) && is_array($this->modules)) {
jimport('joomla.application.module.helper');
foreach($this->modules as $module) {
echo JModuleHelper::renderModule($module);
</div>
7 years 8 months ago #302505
by fan4chevy
Replied by fan4chevy on topic Related Products Go Away When Adding To Cart Main Product
Is there a way when they add to cart the main product that it an stay on that same page so that they can choose related products just after choosing the first, then decide if they want to checkout?
7 years 8 months ago #302513
by Jerome
Replied by Jerome on topic Related Products Go Away When Adding To Cart Main Product
Yes, by not using the legacy "add to cart" system and publishing the "Hikashop Add to Cart notification Plugin" (with the popup mode in its configuration).
Time to create page: 0.142 seconds
