Product Listing Module Can Only Display Categories, Not Products
  • Thank you received: 6
4 years 6 months ago #312160
-- url of the page with the problem -- : www.lastingbeauty.co.nz/the-shop/skin-beauty-shop
-- Joomla version -- : 3.9.12
Is there a good tutorial on the Hikashop Module?
I can't get this version to work.
It will only display items if Type of Content is set to Category.
The related Menu item is set to Products Listing.
Will not show any Products, no matter what I change the settings to.
Thank you.
  • Thank you received: 13069
4 years 6 months ago #312166
Well, to be able to tell you what's wrong, we would need to get a screenshot of the settings of the module when it's not working. With the screenshot you provided, we don't see the settings related to the products so I can't say why one is not configured properly.
4 years 6 months ago #312209
Yes, here.
There is nothing showing on this module now.
Last edit: 4 years 6 months ago by MSTACE.
4 years 6 months ago #312224
You have the "Related products from cart only" setting (shortened to "Related products..." on your screenshot) which is activated.
Since that setting is activated, your module will only take into account the products related to products you already have in the cart.
That's a great option to create a products listing module to be displayed on the checkout to do something similar to this:
www.hikashop.com/marketplace/product/142-checkout-related.html
So you want to turn off that setting. Turn rest of your settings look ok.
4 years 5 months ago #312527
Gees, that was it.
Thank you very much, it is working great!
