How to make products sorted by manufacturer have H1 headings?
4 years 4 months ago #341658 by koshi
-- url of the page with the problem -- : eppmexico.com/productos/categoria/lamira
-- Joomla version -- : 4.1.3
My module which has categories by manufacturer, does not give any H1 headings, even if in every brand description i set it to H1
4 years 4 months ago #341662 by nicolas
What do you mean by "even if in every brand description i set it to H1" ?
There is no h1 setting in brands so I'm not clear on what you're doing.
Also, where exactly do you want h1 headings ?
On the name of the category ? I don't see the page heading on your link.
If you want to display a page heading there, you first need to activate the "show page heading" setting of the menu item via the joomla menu manager.
4 years 4 months ago #341663 by koshi
Thank you for the quick response.
If you go to the main page, eppmexico.com there's the brands section, with all the logos (3M, Ansell, Amigo, Berrendo...) Everything fine here.
If you click on 3M for example, goes to eppmexico.com/productos/categoria/p3m That page, says does not have an H1 heading
4 years 4 months ago #341669 by nicolas
You need to edit the menu item with the title "Productos" via the Joomla menu manager.
There, under the Page Display tab, you need to activate the "Show page heading" setting.
That will display the heading.
Also, under the "Categories options" tab you have the setting "Use the menu name as title". If activated, the heading will use the title/heading configured as a normal Joomla menu item. If turned off, the heading will use the name of the current category / brand as the heading of the page.
4 years 4 months ago - 4 years 4 months ago #341683 by koshi
Tnakh you very much!! I can't believe i skipped that!!
Now, finall question, on my manufacturer page, i have a description, how can i make it appear when they click on each partichular manufacturer?
Already figured it out!! Thank you very much!!!
Can i make subcategories appear as H2?? They are giving me 2 h1 headings
Last edit: 4 years 4 months ago by koshi.
Time to create page: 0.195 seconds
