Products for approval not displaying on backend
  • Thank you received: 6
8 years 2 months ago #227742
-- url of the page with the problem -- : penbyte.com
-- HikaShop version -- : 2.6.1 (bug fix date 1/20/2016)
-- HikaMarket version -- : 1.6.7
-- Joomla version -- : 3.4.8
-- PHP version -- : 5.5
-- Error-message(debug-mod must be tuned on) -- : N/A
I hope you can replicate the problems i am facing now.
I don't know what changes you all made but the system i had before the bug fix on 1/20/2016 is not functioning as well as it did 6months ago. :
Hika Market (see Image)
1) Product Approval - I can not see products that require approval on the back end, I can only view them by clicking on the email i receive that notifies me there is a product for approval (this is different from previous version where I could see products for approval while i was logged in to the backend)
2) Coupon Error (see Image)
Coupons space is showing on products when no coupons are set?
3) Product Modules not updating (see image)
  • Thank you received: 4004
8 years 2 months ago #227744
1/ I'm not able to reproduce your issue.
In order to understand your problem I'll need to see it directly ; so some credentials will be required.
Like usual, please use the "contact us" form in order to send us such private information ; please also put a link to that forum thread so the support team will assign the message to me.
2/ You have created an "item" custom field.
Please create a thread in the HikaShop section of that forum for more details.
3/ I'm afraid that I do not understand what you're talking about.
8 years 2 months ago #227955
Ref 1 - I will send credentials
Ref 2 - I will
Ref 3: On the image -- the modules on the left, are not updating, when the pricing for a product is changed.
8 years 2 months ago #227976
Hello Jerome,
I have sent credentials and have another image to display so you can understand the problem.
Issue: when the product is displayed, a coupon field is also displayed.
1) all discounts and coupons are disabled, and this vendor has not coupons set.
See page:: penbyte.com/movies-new-arrivals.html
Product:: Willit Monetary System (Movie Rental)
Vendor is: W. Iamwe Ph.D.
Admin Access was sent via contact form.
Thanks for your help.
8 years 2 months ago #227998
1 - I checked your website and you do not have any single product in "waiting approval".
The problem "Korean..." does not exist anymore in your products ; I perform check in your products and directly in your database.
Now, if you have a product waiting for approval, please indicate the "product id" of that product.
2 - Please read my messages very very carefully ; if you don't, you won't solve your issue.
You said that you will post your HikaShop related question in the HikaShop section of the forum ; so please do it.
8 years 2 months ago #229551
I have setup a new product that requires approval. see image
The item is not displaying on the admin panel as a product that requires approval
In my setup, Vendors do not have permission to approve products.
I will keep this active until you have a chance to view -
8 years 2 months ago #229554
You currently have two "waiting approval" products and I was able to confirm that the products exist but are not visible in the backend.
I still cannot reproduce your issue but I got one idea on what could generate such issue.
In the file "administrator/components/com_hikamarket/views/productmarket/view.html.php" please replace
		hikamarket::setTitle(JText::_('WAITING_APPROVAL_LIST'), self::icon, self::ctrl.'&task=waitingapproval');
		$vendor = hikamarket::loadVendor(true, false);
		$this->assignRef('vendor', $vendor);
By
		$vendorClass = hikamarket::get('class.vendor');
		$vendor = $vendorClass->get(1);
It will force the main vendor in the backend.
In my side, I have modified entirely the view to remove the code which was coming from the front-end, so the checks on the vendor won't be made in the backend.
8 years 2 months ago #229583
Thank you Jerome,
That fixed the problem
