Options for Products
12 years 7 months ago #26116
I just added Options to one of my Products, but it is not displaying per the instructions and demo site. Do I have to create a content module for Options?
  • Thank you received: 13069
12 years 7 months ago #26131
Could you give more details on what is not displaying as in the demo website ?
You don't need to create any module for options.
12 years 7 months ago #26137
The Option is not displaying on the Product Page.
tacsbeta.com.previewdns.com/index.php?op...yout=show&Itemid=154
12 years 7 months ago #26138
I can see that you edited your product page layout file. Did you do that before updating from a previous version ?
Because if yes, you probably don't have the new code to handle the display of options on the product page.
You would have the delete the customization and reapply it on the new version of that view file.
12 years 7 months ago #26141
Is there a specific file that stores the customization?
12 years 7 months ago #26142
In your case, you must have edited the file show of the view product.
All the view customizations are stored in templates/YOUR_TEMPLATE/html/com_hikashop
