hikashop_social does not work
11 years 10 months ago #55093
hikashop_social ( Google, Twitter, Facebook )
not work :( (shows: {hikashop_social})
work ok :)
work ok :)
work ok :)
What's the problem?
  • Thank you received: 13071
11 years 10 months ago #55127
The hikashop social networks plugin must be disabled. Please plugin it and it should work.
11 years 10 months ago #55325
Hikashop Social Networks Plugin
if disable - does not show anything. OK
if enable - shows {hikashop_social}
if enable and log in - show all OK
if enable and log out - show {hikashop_social}
:blink:
11 years 10 months ago #55363
That's probably because you changed the "access" option of the plugin to something else than public.
Please change it back to public and it should work for all the users, logged in or not.
11 years 4 months ago #80701
I have the same problem.
Hikashop social plug in is enabled. Access level is public. But it shows only {hikashop_social} on the product page.
Here is link: beta.oliver.mn/index.php/classic/classic...t/product/1-9284-266
Thank You for your answer in advance.
Undak
11 years 4 months ago #80908
Could you provide a screenshot of the options screen of the Social networks plugin ? There has to be something not configured right in there.
11 years 4 months ago #80995
Same here,
Hikashop Social Networks Plugin Enabled
Joomla global configuration / System cache off
System - Cache plugin Disabled
Access level public
Browser cache cleared
Don't know where to look more.
Link to a product: http://www.fotoconde.com/hikashop-menu-for-products-listing/product/1-alcacer-do-sal-001
Screenshot of the Social networks plugin:
Thank you,
Mainzer
Last edit: 11 years 4 months ago by Mainzer.
11 years 4 months ago #81212
Here is screen shot of plug-in.
11 years 4 months ago #81307
@Mainzer : I see that you removed the description from the product page or didn't enter any. However, the plugin will only be triggered if there is a description in the product. Please check on that.
The following user(s) said Thank You: Mainzer
11 years 4 months ago #81359
Only the text {hikashop_social} was shown and I have a product descrition and it is public???
I use Joomla 3.02 and Hikashop 2.0.0.
nelkies.nelke.com/index.php/nelkies-shop...lau-weiss-mit-bommel
Hubert
Last edit: 11 years 4 months ago by hnelke.
11 years 4 months ago #81409
Thank you for your reply nicolas,
I added a description to the product but no change.
http://www.fotoconde.com/hikashop-menu-for-products-listing/product/1-alcacer-do-sal-001]
11 years 4 months ago #81552
Would someone be able to provide a backend + FTP access to his website as we can't seem able to reproduce the problem on our end ? There really seem to be a bug somewhere but that might come from a 3rd party extension which would explain why we can't reproduce it on our end.
11 years 4 months ago #81561
I have sent email to You.
BR,
Undak
11 years 4 months ago #81625
after installing two Joomlashine products "imageshow" and "uniform" it happens again.
The socal plugin don't work. ({hikashop_social}
Link: nelkies.nelke.com/index.php/hikashop/product/1-jacke-black
I send the admin access data to This email address is being protected from spambots. You need JavaScript enabled to view it.!
regards Hubert
  • Thank you received: 4004
11 years 4 months ago #81637
Hi undak and hnelke
I have just started to investigate in your website and I saw something "strange".
With these urls, the plugin is working fine :
[undak] beta.oliver.mn/index.php?option=com_hika...duct&task=show&cid=1
[hnelke] nelkies.nelke.com/index.php?option=com_h...uct&&task=show&cid=1
So I think that you have an external plugin or something which is activated in your menu which is incompatible with the HikaShop social plugin.
I will continue to investigate on "what could broke the onAfterRender process".
11 years 4 months ago #81646
Probably this problem has something to do with the joomlashine extensions. Like hnelke I also have Joomlashine template + uniform + imageshow and poweradmin installed.
I already send you access details for backend and ftp to This email address is being protected from spambots. You need JavaScript enabled to view it.
11 years 4 months ago #81649
Hi all,
Thanks to backend access, I could find the problem and, even if I don't know which element creates the incompatibility, I was able to make a patch.
So you can use this version of the plugin and it should fix the issue:
File Attachment:
File Name: plg_conten...2-12.zip
File Size:6 KB
The patch would be included in the next release of HikaShop.
Last edit: 11 years 4 months ago by Jerome.
11 years 4 months ago #81651
Hy Jerome,
just installed new version you posted, but it seems not to solve the problem for me.
I'm curious if it works for hnelke or undak
regards
11 years 4 months ago #81653
Hi again,
Forget my last post, suddenly it works. I just refreshed page several times and it appeared.
@ hnelke and undak, just install the new version of the plugin that Jerome posted and it works fine :)
Thank you Jerome :cheer:
11 years 4 months ago #81662
I have already install the plugin on undak and hnelke websites (for testing the problem and test my fix too).
The following user(s) said Thank You: hnelke
Time to create page: 0.135 seconds
