problem with carousel
11 years 4 months ago #81431
Hi i have a problem with the carousel.
Sometimes dont work fine ...
Please help me.
To see the error, attach 2 pictures one working fine and another working wrong.
11 years 4 months ago #81581
As I can see you seem to have solved your problem.
11 years 4 months ago #81594
The problem is not solved. The problem is that sometimes carousel not work fine
11 years 4 months ago #81615
Could you give us a screenshot of you carousel configuration ?
Are you displaying other modules sometimes or not ?
Is the problem occurring always on the same page ?
11 years 4 months ago #81617
the carousel is only in the home page.
Yes, there are other modules on the same page.
Attach
screenshots of settings.
11 years 4 months ago #81648
Each time I try I have no problem with the carousel.
Weren't you doing modifications on elements displayed in the main page when the problem occurred ?
You parameters seems to be ok.
11 years 4 months ago #81650
if you refresh the home page several times you can see how the carousel crash
  • Thank you received: 4004
11 years 4 months ago #81761
I have see two times the problem by making several refreshs and the carousel does not really crash.
When I had the errors, a lot of images where "404 error" in the carousel. So I think that the missing images broke the carousel script.
11 years 4 months ago #81898
I think that the problem is solved.
Filling the value of widht and height , the carousel works fine .
In my configuration the value heigh was empty.
Time to create page: 0.095 seconds
