Having problems saving product mages
11 years 4 months ago #85857
Hello Using Joomla 3.0.2
Hikashop version : 2.0.0
I'm having problems getting the images to save for the products.
I'll upload an image. Save the image. Sometimes I see duplicate images appear after I do the upload. Sometimes, after saving the product The iamage disappears and only the barcode reappears.
If it helps I'm using images from an earlier install, that I saved to my local compuer. I'm taking the images from the old /public_html/media/com_hikashop/upload folder. However I don't see why that should make a difference. Permissions for the new site's upload folder are 755
Any thoughts?
Rowby
Last edit: 11 years 4 months ago by rowby.
11 years 4 months ago #85916
Can you try with the permission 775 ?
The image system changed, and will be available in the next release.
