FaLang has made an extension module for Hikashop
14 years 4 months ago #57022 by luizarios
While browsing on the Falang website I found out that Falang now has a specific extension for HikaShop ( www.faboba.com/en/composants/falang/extensions.html
I managed to install and use Hikashop and Falang together fine but when I try to install this extension I get the error message JInstaller: :Install: Cannot find Joomla XML setup file
I wonder if anyone has installed this file from the Falang website and what is it meant to do?
14 years 4 months ago #57055 by nicolas
You don't need that.
Just install HikaShop after Falang and HikaShop will install the integration files automatically in Falang.
14 years 4 months ago #57079 by luizarios
yes, I got Falang and Hikashop working without the extension but it just made me curious what it is meant to do and how to install it
14 years 3 months ago #58980 by Kiki3845
I tested it for you !
Just need to import the XML files (one by one) in the configuration panel of Falang, and it works perfectly if you have installed hikashop before falang like me :-)
Really happy about this couple Hikashop/falang.
14 years 3 months ago #59213 by azpayelbd
With Falang, how can I translate the Category Name and the Product Names?
14 years 3 months ago #59216 by nicolas
You can do it directly via the HikaShop interface after turning on the option "Activate the edition of content in multiple languages" of the Languages tab of the configuration
14 years 1 month ago - 14 years 1 month ago #69770 by rockoladeluxe
Works like a charm in the backend. However in the frontend it does not show translations..
Last edit: 14 years 1 month ago by rockoladeluxe. Reason: add mor info
14 years 3 weeks ago #71506 by Papounet01
i had installed falang with hikashop (french and english) then to pass from french to english while i click on eng flag mymainmenu diseapear even if i made the translation through the falang component
thanks for help
14 years 3 weeks ago #71517 by nicolas
It's probably because your mainmenu module is only associated to one language.
For questions related to interaction between Falang and Joomla please contact Falang's support. They will be able to help you better than us.
13 years 8 months ago #92180 by projectsdone
Kiki3845 wrote: I tested it for you !
What kind of XML files would that be? -> where can i find / create them ?
I am using Falang and it's working fine except for Hikashop. It's not displaying the German text of the products.
I also tried setting 'Activate the edition of content in multiple languages' and 'Translation published by default' to yes under Configuration -> Languages. Didn't work..
I need help please !!
13 years 8 months ago #92228 by nicolas
They are in the folder administrator/components/com_hikashop/falang/
The following user(s) said Thank You: projectsdone
13 years 8 months ago #92605 by projectsdone
Thanks!!
Another thing:
You wouldn't know how to change the order creation notification to the right language.
I'm currently using falang and even when the site-language is set to german the notification mail is in english.
Any Solutions?
13 years 8 months ago #92619 by nicolas
Do you have the latest version of HikaShop ?
I recall such issue with older versions of HikaShop.
If not please update.
12 years 3 months ago - 12 years 3 months ago #164673 by lionel75
the URL is now index H like Hikashop here
a---and a capture screen to understand better what mean import xml from falang hikashop extension
hikashop_banner.xml
<?xml version="1.0" ?>
<falang type="contentelement">
<name>Hikashop - Banners</name>
<author>Stéphane Bouey</author>
<version>1.0.0</version>
<description>Definition of banners for the hikashop component</description>
<reference type="content">
.....<table name="hikashop_banner">
..........<field type="referenceid" name="banner_id" translate="0">ID</field>
..........<field type="titletext" name="banner_title" length="255" maxlength="255" translate="1">Banner title</field>
..........<field type="text" name="banner_url" length="255" maxlength="255" translate="1">Banner URL</field>
..........<field type="text" name="banner_image_url" length="255" maxlength="255" translate="1">Banner image URL</field>
..........<field type="text" name="banner_comment" length="255" maxlength="255" translate="1">Banner comment</field>
.....</table>
</reference>
<translationfilters>
</translationfilters>
</falang>
b----capture screen for translate category name here the the step to activate enable the setting
Components -> hikashop -> configuration -> system -> languages -> "actiavte the edition of content in multiple languages " = No/Yes
c---capture screen translation file to update share with hikashop team
best documentation about language in hikashop
Last edit: 12 years 3 months ago by lionel75.
11 years 5 months ago #202945 by raffaelehikashop
HI, I installed the free falang plugin ( www.faboba.com/en/mes-telechargements-ar...ee/falang-2-0-0.html )
How can I use it with Hikashop?
Thank you
Raffaele
11 years 5 months ago #202948 by Xavier
11 years 5 months ago - 11 years 5 months ago #202965 by raffaelehikashop
I uploaded the files in the folder administrator/components/com_hikashop/falang/
Raffaele
Last edit: 11 years 5 months ago by raffaelehikashop.
11 years 5 months ago #202973 by raffaelehikashop
Hi, I turned on "Activate the edition of content in multiple languages" of the Languages tab of the configuration, but it says that only works for comercial versions of hikshop.
Which version should I use? The plugin was together with a template on www.joomlabamboo.com/
I think it is the basic version.
Raffaele
11 years 5 months ago #202979 by Jerome
No, you don't need that plugin.
Please follow instead the instructions here:
demo.hikashop.com/index.php/en/hikashop/...ge/with-translations
11 years 5 months ago #203216 by raffaelehikashop
HI, I Installed the falang plugin, but it doesn't give the possibility to translate the products.
Ho can I go on?
Thank you
Raffaele
