product layout
15 years 10 months ago #4743 by danny
product layout was created by danny
I have my products listed in rows of 5 items.
This is working fine in most browsers except for ie on a wide screen.
instead of showing 5 items its listing them as follows,
row 1 3 items
row 2 1 item
row 3 3 items
row 4 1 item
row 5 3 items
any ideas on how to fix?
cheers
15 years 10 months ago #4745 by nicolas
Replied by nicolas on topic Re: product layout
Could you give the URL where you have the problem as well as the version of IE you're using ?
15 years 10 months ago #4746 by danny
Replied by danny on topic Re: product layout
Sure,
the url is
www.549.com.au/shop/index.php?option=com...out=listing&Itemid=8
i have also sent a screen shot.
Thnaks
15 years 10 months ago #4747 by danny
sorry, ie version 8
15 years 10 months ago #4748 by nicolas
On your link, I just see rows of 4 categories and then when clicking on a category, rows of 3 products, whether it's on chrome or on IE8.
Are you sure you gave me the good link ?
15 years 10 months ago #4752 by danny
yes the link is correct, Have a look at this screen shot and you will see how it dia[plays on my screen, cheers
15 years 10 months ago #4753 by danny
can i have your email please as its not accepting the screen shot image. cheers
15 years 10 months ago #4755 by nicolas
You can send it to nicolas@hikashop.com
15 years 10 months ago #4761 by nicolas
I was able to reproduce it on IE7.
Please go in the menu Display->Views and edit the file listing_div of the views category and product. There, change the line:
$width = (int)(100/$columns);
to
$width = (int)(100/$columns)-1;
and that should solve the problem.
15 years 9 months ago #4914 by danny
I have changed the line of code but it has made no differance. Is there any check boxes i need to check or am i missung something else. Cheers. Danny
15 years 9 months ago #4917 by nicolas
Did you do it for both files ?
15 years 9 months ago #4927 by danny
It is now done in both files but it is not changing the layout. Cheers. Danny
15 years 9 months ago #4928 by nicolas
Are you sure that you did the modification ? I don't see it on your website HTML.
You now have 3 elements per row and the width percentage of each element is 33% where it should be 32% with the modification.
I also do not get the problem on IE7 on your website. Maybe that's because you have three elements per rows ?
15 years 9 months ago #4929 by danny
Im pretty sure everything is ok.
I am currently showing 4 elements per row. Its showing 4 ok in firefox, but still shows the same layout in my previous screenshot that i posted to you in IE.
Thnaks
15 years 9 months ago #4930 by nicolas
I tried on all the browsers I have (IE , opera, chrome, firefox) and I really see only three elements per rows on your link www.549.com.au/shop/index.php?option=com...out=listing&Itemid=8
15 years 9 months ago #4931 by danny
Yes, that particular demo store (ladies clothing) is only set up for 3 items per row. If you click on the furniture tab you will see that it is set up for 4 items per row. I am trying to give potential customers as many visual displays that may appeal to them. Thanks
15 years 9 months ago #4932 by danny
If i set any of my demo stores to 4 items per row, they all list in the odd format of
3 items on the first line
1 item on the next
3 items on the next
i item on the next and so on and so on.
Cheers
15 years 9 months ago #4934 by nicolas
On the furniture link, I still see a width of 25% for each element. However, with the modification I gave you, you should have 24%
The modification is working on our test website so it should work for you as well.
15 years 9 months ago #4937 by danny
Hmmm. I understand what you are saying but its still showing the incorrect layout in IE. I am going to update my ie browser, but its still showing incorrectly in IE7 as per my screen shot. Cheers
15 years 9 months ago #4939 by danny
sorry, ie8
