Menus and categories
14 years 5 months ago #50720 by Sapphire
Hello.... can you tell me if it is possible to create two separate menus with different categories attached to them please?
14 years 5 months ago #50762 by nicolas
Replied by nicolas on topic Re: Menus and categories
Yes of course. In the hikashop options of your menu, you will find the "associated category" option where you can change that.
14 years 5 months ago #50791 by Sapphire
Replied by Sapphire on topic Re: Menus and categories
Hi... thanks... I did do that but I had all the categories associated with the first menu added to the module as well.
14 years 5 months ago #50857 by nicolas
What do you mean ?
Could you give more information on what you did ?
14 years 5 months ago - 14 years 5 months ago #51322 by Sapphire
Hi... what I did was set up my catgories and products. Then I made a menu and associated it with that category module. What I wanted to do is then set up separate list of categories and products and attach it to another menu. I thought I had set up a new categories list under the product categories folder... and added categories and products to this but when I associated that module with a new menu it also brought up the categories from the first menu on the front end and also showed the two lots of categories on my first menu.
eg.
Menu 1
categories
Cars
products
blue
red
Menu 2
categoires
Dolls
products
large
small
Both category lists show on both menus.
Can you see where I am going wrong with this please?
Many thanks
Last edit: 14 years 5 months ago by Sapphire.
14 years 5 months ago #51413 by nicolas
Could you give screenshots of your modules and menus' hikashop options and give a link to the page so that we can see what you did ?
14 years 5 months ago - 14 years 5 months ago #51447 by Sapphire
Hi and thanks.... I have made a real mess I think as I tried to put things right and probably made them worse! I've attached screenshots of my modules, menus and options.... site is www.thetoyattic.co.uk
Many thanks for your help
14 years 5 months ago #51554 by nicolas
Could you give screenshots of your modules and menus' hikashop options ? They can be accessed via the menus Display>Content menus/modules.
14 years 5 months ago #51556 by Sapphire
Sorry - have attached my hikashop options pages now...
Thank you
14 years 5 months ago #51584 by nicolas
Thanks, we're moving forward.
Could you also give screenshots of your modules' hikashop options ? They can be accessed via the link you see in your menus' hikashop options in the "associated modules" option.
14 years 5 months ago #51600 by Sapphire
I have attached the screenshots you asked for.
I really appreciate your help - I'm determined to try to understand this!
Thank you
14 years 5 months ago #51703 by nicolas
So if you want to display different categories on different menus, you need to select the parent category corresponding to one group of categories in the "associated category" option of each menu.
That means that you need to have a multi levels category tree, instead of a one level category tree like you did. Otherwise, you can't have one main category parent of each group of categories.
14 years 5 months ago #51780 by Sapphire
Sorry to come back again but what do you mean by a multi level category tree..... I don't know how to do this.
Thanks again
14 years 5 months ago #51874 by nicolas
I mean to create categories below the main "product category" category and then sub categories below these categories.
You can see the "parent category" option (or "associated category" in some versions of HikaShop) when you edit your categories in order to define the parent category of the current category and thus allowing you to create a multi level categories tree:
www.bryantan.info/uploads/php/e378f5f3be...564288729992d7f9.jpg
14 years 5 months ago - 14 years 5 months ago #52023 by Sapphire
Thank you for sending that example.... what I can't work out is how and where I add the sub categories... e.g. node 2.1 - node 2.11 etc. I can only see the option to add products to categories
14 years 5 months ago #52121 by nicolas
Go in the menu Products->Categories in HikaShop. There, you can manage categories.
The menu Products is only to manage products.
14 years 5 months ago #52310 by Sapphire
Thanks very much for your help. I have worked out how to make the category tree now...... on my main category page though I get links to the sub categories that just run into each other - with no spaces between or formatting. Is there a way to format these links ... or to stop them showing at all so that they are only seen when the main category is clicked on?
14 years 5 months ago #52338 by nicolas
Can you do a screenshot ?
14 years 5 months ago #52351 by Sapphire
Screenshot of the module in the front end attached.
Can you also tell me how it would be possible to just add the separate categories to separate menus.
Thanks again
14 years 5 months ago #52393 by nicolas
You didn't attach the screenshot.
In the hikashop options of each menu item, you have the option "associated category" where you can select the category you want for that menu item.
Time to create page: 0.125 seconds
