Product optie with text
13 years 9 months ago - 13 years 9 months ago #87182 by gerardtb
Is it posible to put a extra text option within Characteristics (product) where the customer can add a arbitrary name?
So not only a pulldown menu (like size or color) but text like a random name.
I hope someone can help me!
Thanks, Gerard
Last edit: 13 years 9 months ago by gerardtb.
13 years 9 months ago #87335 by nicolas
Replied by nicolas on topic Product optie with text
You can do that by creating custom fields of the table "item" and of the type "text" via the menu Display->Custom fields in the Business edition.
13 years 9 months ago #87680 by gerardtb
Replied by gerardtb on topic Product optie with text
I look to your demo of hikashop.
I have a question: I get the Idea that when I make a costum field that this field is available in the hole categorie.
Is this right or is it posible to do it product by product?
13 years 9 months ago #87748 by Mohamed Thelji
Can you explain it more precisely with some screenshots for example ?
13 years 9 months ago #87852 by gerardtb
Hi Mohamed,
In the demo from Hikashop I go toe Custum fields.
There I select a table: product and I have to the right a "add" buton for a categorie.
So I get the Idea that when I want to add a "arbitrary name" to a product I must do it for the hole categorie and not for just for 1 product.
How does this work?
Thanks for your time,
Gerard
13 years 9 months ago #87918 by Xavier
Replied by Xavier on topic Product optie with text
Actually the custom fields can only be applied on a category. Manage it only for products is on our TODO list.
But if you create one in the table product, don't set it as required, let the default value empty.
Then on the product edition page you can specify a name for each product.
And if you let this field empty, nothing will be displayed on frontend.
13 years 9 months ago #88008 by gerardtb
if I understand correctly it is by category but it is posible to get round it and (de)activate the input field for a name by a product.
Is it soon that the option is manage it only for product?
Thanks, Gerard
13 years 9 months ago #88059 by Xavier
If you don't fill the value of the custom field, so it will not be displayed.
The option is on our TODO List like many things, so I can't say when it will be available.
13 years 9 months ago #88254 by gerardtb
I buyed the Businness upgrade of Hikashop today and I try to make a costum field in the productpage.
I
When I make a costum field it is displayed in the productpage but the costumer can't edit it.
When I look to the makeup of the adress field and my costum field there is no difference.
I hope you can help me?
Can you also tell me what de column "core" is in the costum fields column? I also can't set it.
Thanks for you time, Gerard
13 years 9 months ago #88375 by nicolas
You created a custom field of the table "product" and not of the table "item" as I had explained. That's why the user cannot edit it.
The core column tells you if it's a default field of HikaShop or not. The core fields cannot be deleted.
13 years 9 months ago - 13 years 9 months ago #88489 by gerardtb
I'm sorry its my mistake.
Now I have a field and costumer can put arbitrary name in, TOP!
but this "arbitrary costumer name" is not display anywhere not in the mail, invoice, bucketlist.
What do I wrong (again)?
I hope you can help me ones again, Gerard
Last edit: 13 years 9 months ago by gerardtb. Reason: Extra screenshots
13 years 9 months ago #88618 by Xavier
It should be displayed in the email and in the invoice.
In the custom field settings, do you have enabled the display for "frontend" "backend form" and "backend listing" ?
Have you edited any views like "order / product" ?
13 years 9 months ago #88662 by gerardtb
I enabled the "frontend" "backend form" and now also "backend listing" but no diference )-;
The only thing I edit in the views is checkout step.
Do you have a Idea or can I send you extra information?
I hope you can help me.
Best regards, Gerard
13 years 9 months ago #88797 by Xavier
Thanks to see in the view "checkout / cart" if you have a code like:
if(hikashop_level(2) && !empty($this->extraFields['item'])){ foreach($this->extraFields['item'] as $field){ $namekey = $field->field_namekey; if(empty($row->$namekey)) continue; echo '<p class="hikashop_cart_item_'.$namekey.'">'.$this->fieldsClass->getFieldName($field).': '.$this->fieldsClass->show($field,$row->$namekey).'</p>'; } }
13 years 9 months ago #88869 by gerardtb
I found it.
I attached this file
13 years 9 months ago #89059 by nicolas
In HikaShop 2.0, there was a bug with products with characteristics and custom item fields which were not added to the cart along with the product.
So there is a high probability that it comes from that and if that's really that bug you have, updating to the 2.1 release will fix the problem.
So I would recommend you to update by download the latest version on our website and installing it via the joomla installer.
13 years 9 months ago - 13 years 9 months ago #89322 by gerardtb
When will there be the release 2.1.
Is the release within days or weeks?
13 years 9 months ago - 13 years 9 months ago #89415 by Xavier
The release is already available, you can find it on our website.
Last edit: 13 years 9 months ago by Xavier.
13 years 9 months ago #89524 by gerardtb
Hi Xavier,
I update the webshop to version 2.1 in the hope the problem is solved, but the problem is still there )-:
Is it posible to send you the info so you can login to the back-end?
Where can I send the login info to?
I think this is the last big problem (-;
13 years 9 months ago #89740 by nicolas
You can use our contact form:
www.hikashop.com/en/contact-us.html
Please specify the URL of this thread and the URL of a product where you have the problem so that we can easily find it.
The following user(s) said Thank You: gerardtb
Time to create page: 0.115 seconds
