More Products by this artist
15 years 8 months ago #8015 by YakNarak
Hi Nicholas,
I'm trying to show three more products from an artist on the product detail page. I thought it worked well, until I found out that when an artist doesn't have three products, some other products not from the same artist are shown.
Am I doing something wrong or is this a bug.
Please see the definition attached.
Gert.
15 years 8 months ago #8029 by nicolas
You need to publish your module in the option "Modules under the product page" in the config under the tab display and not as a normal joomla module. Is that the case ?
15 years 8 months ago #8234 by YakNarak
Yes I did that.
15 years 8 months ago #8236 by nicolas
Could you give a link to your store so that we can have a look ?
15 years 8 months ago #8751 by YakNarak
Sorry, was in Birma for a couple of days without any internet access. I PM you the login details.
15 years 8 months ago #8760 by nicolas
Could you give an example of a page where it doesn't work like you want ?
15 years 8 months ago #8768 by YakNarak
Did you change anything? The page that always showed wrong is now ok!?
15 years 8 months ago #8769 by nicolas
I didn't change anything yet as I couldn't find anything wrong :p
15 years 8 months ago #8771 by YakNarak
Hmm,
Then it probably has something to do with the fact that I installed the latest version last Thursday. Didn't check it after that any more.
Anyway, will let you know if I find the problem somewhere else.
15 years 8 months ago #8785 by YakNarak
Nicolas,
The problem is still there. Look at this page:
www.thaihandmadecraft.com/cms/index.php?...y_pathway=29&lang=en
You will see that there are products shown from other artists.
Gert.
15 years 8 months ago #8862 by nicolas
Well, your product has two categories, so the module displays the products in the same categories. It's normal.
Now I understand that you would like to see only the products of the category from which the user is coming. In order to do that, you will have to edit the file components/com_hikashop/views/product/view.html.php and change the code:
$query = "SELECT category_id FROM ".hikashop::table('product_category').' WHERE product_id='.$product_id.' ORDER BY ordering';
$database->setQuery($query);
$pageInfo->filter->cid = $database->loadResultArray();
to the code:
$pathway = JRequest::getInt('category_pathway',0);
if(empty($pathway)){
//load products in the same categories
}else{
$pageInfo->filter->cid = array($pathway);
15 years 8 months ago #8875 by YakNarak
Thanks so much Nicholas,
Working fine now!
Gert.
15 years 8 months ago #9021 by YakNarak
Hi Nicholas,
Unfortunately it's still not what I need. Now if I first go to the category artists and then select a product it goes well. But if I start from the category product categories it shows products from the product category, not from the artist.
What I need is that whereever I come from, if I display a product page, on that page I only want to see products that were made by the same artist as the product I am showing.
Any idea how I can achieve that?
Gert.
15 years 8 months ago #9035 by nicolas
In order to do that, you will have revert the previous change and edit the file components/com_hikashop/views/product/view.html.php and change the code:
to the code:
//load products in the same first category
$query = "SELECT category_id FROM ".hikashop::table('product_category').' WHERE product_id='.$product_id.' ORDER BY product_category_id ASC LIMIT 1';
And, for all your products, the first category you add to it should be the artist category. If it's always the last, then, you should replace ASC by DESC.
15 years 8 months ago #9061 by YakNarak
Followed your recommendations but still the same problem.
Changed your code to DESC because the artist is the second category. But it doesn't change anything.
Gert.
15 years 8 months ago #9064 by nicolas
Could you paste the code around your modifications ?
15 years 8 months ago #9130 by YakNarak
Not sure what you mean. What would you like to see? By the way, you can still login to the site if it helps.
Gert.
15 years 8 months ago #9132 by YakNarak
Nicolas,
Solved the issue already. It was a problem in the database, not in the code.
Gert.
15 years 2 months ago #24854 by YakNarak
Nicholas,
After working almost 6 months with the system I still have a problem with the above.
The problem is that if an artist has a lower id than the product category it always comes in the first place, even if i add it after the product category.
The ASC, DESC part is therefor not working.
Any other way this can be solved?
Gert.
15 years 2 months ago #24856 by nicolas
Are you sure that you're using the code ORDER BY product_category_id ASC and not ORDER BY category_id ASC ?
Because product_category_id will order the categories with the first one being the first added in the categories of the product while category_id will order the categories with the first one being the first category created, which is what you're describing.
