Hikaserial - Add a serial key of front
10 years 7 months ago #237137 by neo191987
Hi can you add a function to add serial key in front of the site. I do not see it as an option. Since I will deal mainly with hikaserial. Thanks in advance.
10 years 7 months ago #237138 by Jerome
Please describe your request with a lot more details.
I'm sorry but with your current description I'm not able to understand what you want.
10 years 7 months ago #237234 by neo191987
Hi, I mean that you can create packets but can not add serial.
There are features listing and export but not to add
10 years 7 months ago #237253 by Jerome
That's right ; there is no "serial add" function because the current implementation is more oriented around the pack management and the usage of serial generators.
The edition, creation and import of serials is in the TODO list but we wanted to have enough feedback on the current implementation before starting to work on the next steps.
The following user(s) said Thank You: neo191987
10 years 7 months ago #237451 by neo191987
Hi I want to first thank you for the good support. I want to ask you if it is possible to add this feature to the autumn because I really need this option. I'm headed for the sale of digital games and my partners will need to manually bring their serial keys for different platforms such as Steam, Uplay, Origin, etc. Thanks in advance and once again thank you for the good support.
10 years 7 months ago #237514 by Jerome
I'm not sure what I would be able to do ; I don't have a precise planning because things can evolve regarding the custom developments or missions I got.
Maybe the serial import would be better than the edition.
10 years 7 months ago #237527 by neo191987
Thanks for the reply. The important thing is to have a way to add serial keys from the frontend.
10 years 6 months ago #238751 by neo191987
Hi, as far as I can see in the serialsmarket folder has a file for feature import serial but it is not active. How can I activate it? I really need this feature.
10 years 6 months ago #238752 by Jerome
To active it ; you first need to finish it and provide the code to perform the import (with all security checks).
10 years 6 months ago #238784 by neo191987
Thank you. I count on you for that. Otherwise I can not use components for my purposes.
10 years 6 months ago #239538 by Jerome
We just released HikaSerial 1.10.4 with HikaMarket 1.7.0 support and also serial import for vendors.
For the moment it is not available through the automatic update system but you can download the package manually in the "my subscriptions" page.
10 years 6 months ago #239556 by neo191987
Thank you very much. This is great news for me.
10 years 4 months ago #245475 by neo191987
Hi in test I noticed that serial keys can be duplicated. Can it somehow avoid it.
10 years 4 months ago #245477 by Jerome
In which way ?
10 years 4 months ago #245501 by neo191987
Hi I made a video of this test to see exactly what was happening. When importing may mistakenly introduce the same serial key. I mean you can somehow avoid this duplication, as detect this duplication and prevent.
www.youtube.com/watch?v=ILU6vQQdJsk&feature=youtu.be
10 years 4 months ago #245532 by Jerome
Ah, I see.
The front-end import is using "handleTextContent" and not the "handleCsvContent" ; and currently, the "check duplicate serials" is just available in the CSV import.
I'll add the support of that option in the Text import for the next release.
9 years 10 months ago #260064 by neo191987
Hi does there exist any development on Hikaserial function "handleTextContent" mentioned above. I've read somewhere that there will be a new version, you will have this feature and approximately how long it will be released.
9 years 10 months ago #260093 by Jerome
The support of "check duplicate" has been integrated in HikaSerial end of July.
With my work on HikaShop 3.0 ; the other development I got for HikaSerial has been delayed.
Right now, I have to see if I just try to publish "HikaSerial 1.10.5" or if I finish my developments and a major release.
9 years 10 months ago #260123 by neo191987
Jerome wrote: Hi,
Ah, I see.
Hi there is still a problem with duplication. Obviously I have not asked the right question.
9 years 10 months ago #260124 by Jerome
I'm afraid that I wasn't clear enough.
The support of "check duplicate" has been integrated in the HikaSerial source code end of July.
HikaSerial 1.10.4 has been release and his code is fixed ; I do not update a package several months after his release.
At least if we found a important bug, we release a new minor release ; but in all cases updates are coming from new releases.
Time to create page: 0.118 seconds
