window platform IIS encounter problem at display
15 years 1 month ago #25942 by ler@singmuiheng.com
first of all, i would like to say that i have two same version joomla 1.5 and hikashop 1.4.7 on both linux and window platform server
linux have no problem for all the upgrade to 1.5.3
but on windows
encounter strange issue after upgrade as message show that upgrade successful but all the file on server was not replaced and still showing 1.4.7 version
i had done a manual upload to overwrite all the old file
2nd, after patching , found that my layout at front end runs (not centered but display as centered), go to configuration and display-->content menu to change , found out the radio box is checked at "not centered",
try to change it to "centered" but after click applied/save, it still go back to "not centered"
feed back to server member if it is file permission issue but they say they confirm all the file permission is correct and they remind me i m on window platform
is that any thing i need to take note on window platform? and now how should i change it back to "not centered" ?
15 years 1 month ago #25956 by nicolas
Your first problem indeed sounds like an access right issue.
For your second centering problem could you give a link to that page so that we can see ?
15 years 1 month ago #25965 by ler@singmuiheng.com
hi
the second problem solved by delete all the custom view in the display
thanks for your reply
but the first problem still remain , i tried on another server which is oso window platform , same problem exist
15 years 1 month ago #25970 by nicolas
We need more information to answer you on that first problem.
Could you give the exact error message you get when you install ?
What kind of windows are you using and which version of IIS are you using ?
Do you have similar error messages when you install other components on your website ?
15 years 1 month ago #25971 by ler@singmuiheng.com
no error messages displayed instead it show hikashop installed successfully and soon it prompt me the latest version 1.5.3 and ask me update
other platform do not have this issue
15 years 1 month ago #25972 by nicolas
So I understand that you're trying to update HikaShop from a previous version to the latest version, right ?
Did you setup the FTP layer in joomla ?
15 years 1 month ago #26146 by ler@singmuiheng.com
Now i found some more problem about the view
after disabling text centered althought all the text is now alight to left , but if the product name is too short, the over all view is still going to the center
refer
singmuiheng.com/index.php?option=com_hik...ing-books-&Itemid=70
how could i make it all alight to left?
15 years 1 month ago #26147 by nicolas
I don't see any problem regarding that on your link with Chrome. Did you use another browser ? Does it work correctly with Chrome for you ?
Maybe you could do a screenshot and circle out the problem as maybe I missed it ?
15 years 1 month ago #26152 by ler@singmuiheng.com
you are right
it is perfectly fine while using chrome
i wasted the whole morning on IE =="
But is it the IE problem or css problem? As it look like this in IE
www.singmuiheng.com/error.jpg
and even visiting this forum there is also js error on IE
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Tue, 27 Sep 2011 06:46:00 UTC
Message: Object doesn't support this property or method
Line: 135
Char: 9
Code: 0
URI: www.hikashop.com/components/com_kunena/t...lt/js/kunenaforum.js
15 years 1 month ago #26153 by nicolas
It seems that IE doesn't process your CSS in the same way as Chrome.
You can add the CSS below in your template CSS to fix the problem:
#hikashop_category_information_module_48 div.hikashop_subcontainer {
text-align: left !important;
15 years 1 month ago #26155 by ler@singmuiheng.com
you are really a great helper
it works perfectly !!
thanks a lot
15 years 1 month ago #26156 by ler@singmuiheng.com
singmuiheng.com/index.php?option=com_hik...ut=listing&Itemid=64
product listing page working fine but now category listing page still same problem
15 years 1 month ago #26161 by nicolas
You should add a similar CSS for it:
#hikashop_category_information_menu_64 div.hikashop_subcontainer {
15 years 2 weeks ago #28179 by ler@singmuiheng.com
found another serious problem
think it happen since we do the upgrade ealier but we only notice it now
all the item selected ws not shown in the cart
please have a test on our live site
www.singmuiheng.com
How can i verify the cause of this problem?
15 years 2 weeks ago #28190 by nicolas
Please follow the procedure explained there:
www.hikashop.com/en/support/documentatio...lity-issues.html#SQL
The database structure might not have been updated properly during the update.
