- Thank you received: 2
Problem with same data installation
7 years 7 months ago - 7 years 7 months ago #304475
by ronron
Problem with same data installation was created by ronron
Last edit: 7 years 7 months ago by ronron.
7 years 7 months ago #304482
Replied by nicolas on topic Problem with same data installation
Do you have a dataexample.zip in the tmp folder of your website ?
Do you have a dataexample folder in that tmp folder ?
Note that you can again go through the wizard and load the data sample by going to the URL administrator/index.php?option=com_hikashop&ctrl=update&task=wizard
There are many reasons which could lead to the data sample not being downloaded, copied to the tmp folder, extracted, etc. For example:
- not enough time to download the zip -> you should increase the max_execution_time setting of your php.ini
- not enough time to extract the zip -> you should increase the max_execution_time setting of your php.ini
- not enough memory to extract the zip -> you should increase the memory_limit setting of your php.ini
- couldn't access the zip -> there is a firewall preventing outgoing connections from your server at your hosting
- couldn't copy the files of the zip once extracted -> the tmp folder is not writable
and others that don't come to mind right now.
The last one I said is probably not that since your screenshots says that the tmp folder is writable.
But it could be something else.
The first thing is to try again the wizard and see if that helps and check the tmp folder to see what was done by the wizard.
Time to create page: 0.260 seconds
