- Thank you received: 11
Product Detail at Backend Order Layout Problem
- ler@singmuiheng.com
4 years 10 months ago #337151
by ler@singmuiheng.com
-- Joomla version -- : 3.8.6
-- PHP version -- : 7.3.27
-- Browser(s) name and version -- : Google Chrome
Hi, may I know why when go to backend order and click product detail page the layout since like got problem, any way to adjust the layout?
Please see the screenshot as attached. Thanks
4 years 10 months ago #337158
Replied by nicolas on topic Product Detail at Backend Order Layout Problem
It's probably because of your template not including the CSS when the tmpl parameter in the URL is set to "component".
Normally, you have a file component.php which does this.
What you can try is to replace that file templates/YOUR_TEMPLATE/component.php by the default one of Joomla in templates/protostar/component.php (make a backup in case it creates some kind of problem).
Time to create page: 0.147 seconds
