Bug in assigning images to products
16 years 2 weeks ago #677
by Michel
Bug in assigning images to products was created by Michel
Hi HikaShop Team,
When I assign an image to a product, after selecting the image, clicking ok in the popup then closing it, the image will not display in the product window. If I save the product at this stage, the image will not be assigned.
The workaround I found is to go back to another screen (for example the product list) without saving the product, and then going again to the product page. Then the image is displayed and effectively assigned to the product.
Is this a known issue or am I doing something wrong?
Thanks in advance!
Cheers
Thanks in advance!
Cheers
16 years 2 weeks ago #694
Replied by nicolas on topic Re: Bug in assigning images to products
The assignation of images and of category use roughly the same javascript so I wouldn't be surprised that it's the exact same problem as your other thread:
www.hikashop.com/en/support/forum/3-bug-...to-products.html#693
16 years 2 weeks ago #775
by Michel
Replied by Michel on topic Re: Bug in assigning images to products
Yes, absolutely - when I tried to reinstall everything on a new setup it also worked fine. Thanks!
Time to create page: 0.042 seconds
