Module Class Suffix doesnt work
15 years 11 months ago #2323
by LAS_VEGAS
Module Class Suffix doesnt work was created by LAS_VEGAS
I added shopping cart module to position 'left'. I set "Module Class Suffix" as "_menu". But on the front end, this setting is not 'respected'. The module is put inside with wrong css class:
It should be:
This works fine with main menu module for example.
<div class="module">...</div>
It should be:
<div class="module_menu">...</div>
15 years 11 months ago - 15 years 11 months ago #2325
Replied by nicolas on topic Re: Module Class Suffix doesnt work
That's interesting.
It actually works on our dev website but doesn't on our demo website. We will have to investigate...
It's actually a parameter which is handled automatically by joomla and since it was working on our dev website, we thought it would be working all the time.
I'll update that thread when we find the problem.
Last edit: 15 years 11 months ago by nicolas.
15 years 11 months ago #2326
You can edit the file modules/mod_hikashop/mod_hikashop.php and the file modules/mod_hikashop_cart/mod_hikashop_cart.php and change in each the code
to
foreach($module_options as $key => $option){
$params->set($key,$option);
if($key !='moduleclass_sfx'){
15 years 11 months ago #2329
by LAS_VEGAS
Replied by LAS_VEGAS on topic Re: Module Class Suffix doesnt work
Thanks, that code fixes the problem.
15 years 11 months ago #2675
by reace
Replied by reace on topic Re: Module Class Suffix doesnt work
is it not better to use a preceeding space for module_suffix rather then '_' as the space should separate the new suffix from the old without losing formatting etc?
Ive not done much work with these as yet .
15 years 11 months ago #2685
If you use a space, that means that the module div will have two classes:
module new_class
But if you user an _, it will only have one class which is different from the default one:
module_new_class
Ususally, I used that option to set the suffix _menu which is defined for the menu module in order to add a chrome around the module when displayed on the left or right columns of the template. That's a standard way of doing it in joomla.
module new_class
module_new_class
