Product Characteristics - order not being saved.
15 years 11 months ago #3377 by brainforge
Changed the value of the order column clicked apply, order not saved, returned original values.
To workaround corrected values in database.
15 years 11 months ago #3408 by nicolas
Thank you for that bug report. That is now fixed on our end and will be included in next release.
In the mean time, you can change the code
$query = 'INSERT IGNORE INTO '.hikashop::table('variant').' (variant_characteristic_id,variant_product_id,ordering) VALUES '.implode(',',$insert).';';
to
$query = 'REPLACE INTO '.hikashop::table('variant').' (variant_characteristic_id,variant_product_id,ordering) VALUES '.implode(',',$insert).';';
in the file adminsitrator/components/com_hikashop/classes/product.php near line 350 to fix the problem.
Time to create page: 0.039 seconds
