Images of variant not loaded
15 years 5 months ago #13505 by Nello
Hi Nicolas, This is my problem.
I set two CHARACTERISTICS: Colors and Size. So I manage the variants and turn on some colors.
Now I load for each color a picture about that particular color, but in frontend when I choose that color the images do not load...
15 years 5 months ago #13540 by nicolas
It might happen if you have a javascript error on the page, or if you changed the view of the product page and removed/broke some of the HTML in it. Could you give a link to that page so that we can have a look.
15 years 5 months ago #13585 by Nello
www.stylover.com/index.php?option=com_co...rada&catid=2:current
This is the link of page where I have the problem. Try to change "Colore" from "Verde" to "Beige". It should change the pics but it doesn't works.
15 years 5 months ago - 15 years 5 months ago #13588 by Nello
it seems a problem of template
Last edit: 15 years 5 months ago by Nello.
15 years 5 months ago #13601 by nicolas
I just tried your link but it doesn't work.
15 years 5 months ago - 15 years 5 months ago #13605 by Nello
You mean the link is corrupted?
15 years 5 months ago #13613 by nicolas
Your link now works. Not sure why it didn't before.
The images change when changing the characteristics on that page when we change the characteristics values dropdowns.
15 years 5 months ago #13616 by Nello
Nicolas I found the problem. It is in wiew>product>show... due to a change that I made.
I solved a part of the problem, but when I choose a variant the picture becomes big. Before now I solved this via css but now it no more work
15 years 5 months ago #13622 by Nello
Nicolas for me the problem is here. Please, check out the page. The variant image lose the style and also the pop up mode no more works.
<?php
if(!empty($this->element->variants)){
foreach($this->element->variants as $variant){
$variant_name = array();
if(!empty($variant->characteristics)){
foreach($variant->characteristics as $k => $ch){
$variant_name[]=$ch->characteristic_id;
$variant_name = implode('_',$variant_name);
if(!empty($variant->images)){
<div id="hikashop_product_image_<?php echo $variant_name;?>" style="display:none;">
<div id="hikashop_main_image_div_<?php echo $variant_name;?>" >
<?php
$image = reset($variant->images);
if(!$this->config->get('thumbnail')){
echo '<img src="'.$this->image->uploadFolder_url.$image->file_path.'" alt="'.$image->file_name.'" id="hikashop_main_image_'.$variant_name.'" style="margin-right:8px;margin-bottom:8px;display:block;vertical-align:top;float:left;padding:4px;border:1px solid #666666;" />';
}else{
$style='';
if(count($variant->images)>1){
$height = $this->config->get('thumbnail_y');
if(!empty($height)){
$style=' style="height:'.($height+5).'px;"';
<div class="hikashop_product_main_image_thumb" id="hikashop_main_image_thumb_div_<?php echo $variant_name;?>" <?php echo $style;?>>
<?php echo $this->image->display($image->file_path,true,$image->file_name,'id="hikashop_main_image_'.$variant_name.'" style="margin-right:8px;margin-bottom:8px;display:block;vertical-align:top;float:left;padding:4px;border:1px solid #666666;"','id="hikashop_main_image_'.$variant_name.'_link"'); ?>
</div>
<?php
</div><div id="hikashop_small_image_div_<?php echo $variant_name;?>"><?php
foreach($variant->images as $image){
echo $this->image->display($image->file_path,'hikashop_main_image_'.$variant_name,$image->file_name,'class="hikashop_child_image"');
</div>
</div>
15 years 5 months ago #13626 by nicolas
Hard to say... I just checked your page and you had an error in your code so it's even harder to understand the problem without seeing it.
15 years 5 months ago #13627 by Nello
Try now!
15 years 5 months ago #13631 by nicolas
That fact that the popup do not work is because the modalizer library is triggered on the page loading to initialize the events on all the links of the page, but not after clicking on the images like we do with the default code.
For the big image when changing the characteristics, that's because you need to set the height on it when displaying it, like the JS does automatically when you go on a small image after that.
15 years 5 months ago #13658 by Nello
How can I set the height?
15 years 5 months ago #13662 by Nello
Ok I resolved the big image...
15 years 5 months ago #13664 by nicolas
For the popup, you need to add some modalizer js code to dynamically generate the popup from the link of the image when the image is clicked on (with an onclick attribute). I can't tell you the code to use as I don't know how modalizer works.
15 years 5 months ago #13673 by Nello
Can you show me where is the code that generate the link of the small image?
Thank you!
15 years 5 months ago #13687 by nicolas
The small image link is generated in the function display of the file administrator/components/com_hikashop/helper/image.php
15 years 5 months ago #14702 by Nello
Nicolas, can you tell me the code to add modalizer to the small images, after selecting a variant?
This is an example page
Thank you!
15 years 5 months ago #14704 by nicolas
I don't know actually. I just know that it's how it should be done.
15 years 5 months ago #14707 by Nello
Modalizer don't work after selecting a variant... this is not good for me.
Time to create page: 0.297 seconds
