custom text field problem on field step.
15 years 4 months ago #19056 by Rickhavoc
it happening again where the page flickers and it doesn't go to the next step. check it out. if i keep trying to force myself through the process meaning having to keep click next i can enter the card info but after hitting next there it bounces me back to the field step with whats on the field step.
15 years 4 months ago #19057 by nicolas
Could you disable the custom text custom field and try again ?
15 years 4 months ago #19061 by Rickhavoc
it goes through if i disable it.
15 years 4 months ago #19063 by nicolas
Please do a screenshot of the configuration of that custom field.
15 years 4 months ago #19065 by Rickhavoc
here you go my friend :)
15 years 4 months ago #19068 by nicolas
Please change the type to something else temporarily and make sure that the required option is turned off and put back the type and save. Then publish it and try again.
15 years 4 months ago #19072 by Rickhavoc
now it doesn't flicker on the page of the fields but it flickers on the page that has this information
You chose the shipping method: Test
You chose the payment method: Credit card
after i click next there i get sent back to the fields page with this..
when i changed the type and saved , it stayed with the same column name of "customtext_165_14_03_50 "
15 years 4 months ago #19074 by nicolas
And everything works properly if you don't publish the field ?
15 years 4 months ago #19075 by Rickhavoc
15 years 4 months ago #19076 by nicolas
Please logout and login and try again to fill the form with the custom field with the type text. Do you have any problems ?
15 years 4 months ago #19089 by Rickhavoc
clean cache in browser and joomla, and still same issue.
15 years 4 months ago #19105 by nicolas
What you could do is that instead of using a custom field of the type "custom text", you could just edit the file fields of the view checkout via the menu Display->Views and add your text there directly. That will avoid the problem.
On our end, we'll fix that for next release.
