- Thank you received: 2
Problem with more then one characteristics
15 years 3 months ago #21957
by Nello
Problem with more then one characteristics was created by Nello
If I have only one kind of characteristic and I delete one of them, this disappear in front-end.
Instead, if I have two or more then one kinds of characteristics and I delete a combination, this appear on front end, but as not available.
Why doesn't disappear?
For example take a look here: www.hidesign.it/it/catalogo/product/show/cid-302/alma
I have delete the combination "base-bianco", but it is in front end and appear as not available.
15 years 3 months ago #21974
Replied by nicolas on topic Re: Problem with more then one characteristics
When you have more that one characteristic, the system cannot update dynamically the values of the dropdowns so if you have bianco used for another type than base, bianco still needs to be in the dropdown so that you can choose the option laccato-bianco on the dropdowns. That's why it's displayed as not available.
15 years 3 months ago #21975
by Nello
Replied by Nello on topic Re: Problem with more then one characteristics
Yes I had assumed that, but on the front end creates a bit of confusion.
I think it would be more efficient to update dynamically.
Ok! Thank you!
Ok! Thank you!
15 years 3 months ago #21981
Sure it would
But it's not so easy to do.
